Rob66 Posted February 14, 2010 Share Posted February 14, 2010 Hallo I have a DVB Satellite receiver (PCI) in combination with DVBViewer. Working perfect. I want to Re-Route the DVBViewer output to a input device that can be select in the Skype video setup (like a Webcam). The DVBViewer has a Plug-in "Net stream" interface complete with IP Address etc... I did it long time ago with the DC10 Capture card that install a device that directly can be selected in Skype. It was Fun, Quality is not inportend. QST. How can i install / connect the netstream that result in a device to be selected in Skype? Thks Rob Quote Link to comment
Rob66 Posted February 14, 2010 Author Share Posted February 14, 2010 My OS is Windows 7 64 bit and i running DVBViewer. PLS, Go to taskbar point the cursor at DVBViewer. you will see a small video picture above the icon. It is possible.... Thks Robert Quote Link to comment
Lars_MQ Posted February 14, 2010 Share Posted February 14, 2010 Well if you seem to know so much more than me about this you should be able to solve the problem yourself. Quote Link to comment
Rob66 Posted February 14, 2010 Author Share Posted February 14, 2010 That is not the case. Can be done in visualbasic. I am not a Programmer in Virtualbasic. So i need help.... Thks Robert Quote Link to comment
Lars_MQ Posted February 14, 2010 Share Posted February 14, 2010 Ok it seems, you not the "ideal expert". So maybe you just trust my experience and take a "not possible" as answer. Well that's unless you're able to write something like the recording service yourself... Quote Link to comment
Rob66 Posted February 15, 2010 Author Share Posted February 15, 2010 Thanks for your advice. Robert Quote Link to comment
