TGM Posted February 22, 2010 Posted February 22, 2010 Hi there I have made a blind scan i TransEdit IPTV, and found 145 IPTV channels, but I can't export them into DVBViewer 4.2.1.0. The error message is "Sorry - cannot export since DVBViewer 2.1 (or later) is not present" But the problem is DVBViewer IS present and above version 2.1. I have then tried to save the channel list in a transponder ini-file, and then import that to DVBViewer, but nothing happens, it wont import. Last I have tried to do the same channel scan inside DVBViewer, but as far as I can see, you can't scan for IPTV channels inside DVBViewer. Can anybody help in getting my channels into DVBViewer? Thanks -TGM Quote
PeterF Posted February 22, 2010 Posted February 22, 2010 have you installed the Transedit in the same folder as DVBV? PeterF Quote
TGM Posted February 23, 2010 Author Posted February 23, 2010 No ... does that help I will try that Thx Quote
PeterF Posted February 23, 2010 Posted February 23, 2010 (edited) yes, it will help you... PeterF from the manual: Installation Store TransEdit.exe and Huffman.dll in the DVBViewer installation folder (where DVBViewer.exe is located). TransEdit requires DVBViewer Pro 3.5 or later, or DVBViewer GE 2.0 or later. Without a DVBViewer installation some functions are not available. Create a shortcut on your desktop or in the startmenu, if you like, by dragging the file with the right mouse button to the desired location. Edited February 23, 2010 by PeterF Quote
TGM Posted February 23, 2010 Author Posted February 23, 2010 Okay, now I'm confused. I'm using TransEditIPTV and not TransEdit, and TransEditIPTV still doesn't work even if it is in same folder as DVBViewer. If I try using TransEdit, and choose IPTV, then I can't make a blindscan, and I can't type in IP addresses, since it wont accept the second "." Now what ? Quote
TGM Posted February 23, 2010 Author Posted February 23, 2010 Somehow I managed to get a few channels transfered into DVBViewer, but when I select a channel to watch, it gives an error "No hardware avaliable". What are it talking about , I dont use any hardware, it is IPTV channels, scanned from the network on the computer through the Network cable. Quote
PeterF Posted February 23, 2010 Posted February 23, 2010 have you added a IPTV-Device in the Hardwaresection in DVBV? PeterF Quote
TGM Posted February 23, 2010 Author Posted February 23, 2010 No I hadn't, I couldn't figure out how to do it, but now I found out, and I can see TV. BIG WAVES Thanks PeterF, and for your patience Quote
