Cesare Posted December 7, 2002 Share Posted December 7, 2002 Hi. The last version 197R6 has two new XVR output render. I tried, but with strange things in the output area.... I did'nt find indication about it in the Help (Christian have no time for this now, I think). How and when XVR can be used? Cesare Quote Link to comment
Guest DAvenger Posted December 7, 2002 Share Posted December 7, 2002 I wouldn't touch it at the moment. After two or three updates it should work without any problems <_ Quote Link to comment
Guest Michael Posted December 7, 2002 Share Posted December 7, 2002 i haven't any of that options :/ Quote Link to comment
Guest hackbart Posted December 13, 2002 Share Posted December 13, 2002 well i uploaded a few days ago the version with xvr, but during incombatibility issues i removed the two additional xvr modes from the options. If you would enable it (for testing only), all you need is to edit the setup.ini. There should be a line in [General] , called Output just put a value 2 or 3 inside and copy the xvr into the filters directory. Keep in mind RGB does not work fine. Overlay runs damn fast but has nasty stripes in the left and the colorsettings are disabled (because my old routines do not calculate the correct value for the xvr and all you saw was some sort of LSD TV). Christian Quote Link to comment
