Bravia DLNA and liveTV
SoftwareFailure
Hello,
I'm using the recording service to stream iptv to my ps3 using upnp, everything is working fine, thanks for that ;)
Now I'm trying to do the same on my sony bravia tv (kdl-32v5500).
Streaming recordings is ok (as writen in the changelog of 1.5.0.60) but liveTV does not work :D
Is there any chance to get it work ?
A User and I tried for several weeks to get it to work but it simply won't do it. I have no clue where the problem lies.
Thank you for your quick answer.
How are handled the channels using upnp, are they considered as files ?
In that case have you ever tried to change file extension from .ts to .m2t ?
The reason I ask you that is because when I put a recorded file (from IPTV channel) on a usb stick and play it on the tv I have to change extension from .ts to .m2t in order to see it on the tv (in the files list).
I've heard somewhere that bravia tvs can only playback h.264 if they have a .m2t extension (like HDV).
So I was surprised that it is possible to playbackfiles from h.264 recorded channels with .ts extension.
The recordings are TS files. So no problem there, channels are handled in a similar way. Believe me we did try everything possible (including serveral wireshark logs) and even some things impossible. ;)
OK, finally I found a solution.
First I start the recording service, then another upnp server -> Wild media server.
In wms I create a new internet tv link, put "http://192.168.1.7:7522/upnp/channelstream/00084.ts" as the path of this link (so link to a recording service channel stream) and tell wms to not transcode the stream.
Last in wms, I set the MIME-type and DLNA parameter to ts and MPEG_TS_SD_EU_ISO and start the server.
My iptv provider is streaming h264(sd&hd) content inside ts over udp.
Here is the upnp presentation :
POST /UPnPServices/ContentDirectory/control HTTP/1.1
X-AV-Physical-Unit-Info: pa="BRAVIA KDL-32V5500     ";
X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-32V5500     "; mv="1.7";
Host: 192.168.1.7:3406
User-Agent: UPnP/1.0 DLNADOC/1.50
Content-Length: 674
Content-Type: text/xml; charset="utf-8"
SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#Browse"
<?xml version="1.0"?><s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><u:Browse xmlns:u="urn:schemas-upnp-org:service:ContentDirectory:1"><ObjectID>085C4743-A4DC-43B3-AB29-957BB759C6DF</ObjectID><BrowseFlag>BrowseDirectChildren</BrowseFlag><Filter>dc:title,av:mediaClass,dc:date,@childCount,res,upnp:class,res@resolution,upnp
:album,upnp:genre,upnp:albumArtURI,upnp:albumArtURI@dlna:profileID,dc:creator,res
@size,res@duration,res@bitrate,res@protocolInfo</Filter><StartingIndex>0</StartingIndex><RequestedCount>10</RequestedCount><SortCriteria></SortCriteria></u:Browse></s:Body></s:Envelope>HTTP/1.1 200 OK
Content-Length: 3140
Transfer-Encoding: chunked
transferMode.dlna.org: Streaming
Accept-Ranges: bytes
Date: Thu, 1 Apr 2010 20:53:31 +0200
Cache-Control: no-cache
Expires: 0
LAST-MODIFIED: Thu, 1 Apr 2010 20:53:31 +0200
EXT:
Server: Windows/5.12600 UPnP/1.0 DLNADOC/1.50 Wild Media Server (UPnP, DLNA, HTTP)/0.73
00000C44
<?xml version="1.0" encoding="utf-8"?>
   <s:Body>
     <u:BrowseResponse xmlns:u="urn:schemas-upnp-org:service:ContentDirectory:1">
       <Result><DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/" xmlns:av="urn:schemas-sony-com:av" xmlns:dlna="urn:schemas-dlna-org:metadata-1-0/">
   <item id="207ddbaf-cb08-4fda-a2f5-a830f9bd4831" parentID="085C4743-A4DC-43B3-AB29-957BB759C6DF" restricted="1">
     <dc:title>(?) ARTE HD</dc:title>
     <upnp:class>object.item.videoItem</upnp:class>
     <dc:date>2010-04-01T20:53:31</dc:date>
     <dc:creator>[unknown Author]</dc:creator>
     <upnp:album>Internet Television</upnp:album>
     <upnp:genre>[unknown Genre]</upnp:genre>
     <res size="42949672950" av:pixelAspectRatio="1:1" protocolInfo="http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_EU_ISO;DLNA.ORG_OP=00;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=61
F00000000000000000000000000000">http://192.168.1.7:7522/upnp/channelstream/00000.ts</res>
   </item>
   <item id="3bbf4c5d-2417-44dc-a84b-7d6b6ba2b180" parentID="085C4743-A4DC-43B3-AB29-957BB759C6DF" restricted="1">
     <dc:title>(?) NT1</dc:title>
     <res size="42949672950" av:pixelAspectRatio="1:1" protocolInfo="http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_EU_ISO;DLNA.ORG_OP=00;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=6
1F00000000000000000000000000000">http://192.168.1.7:7522/upnp/channelstream/00083.ts</res>
   </item>
   <item id="a5fd51a5-6ae6-4066-b101-d05270d88350" parentID="085C4743-A4DC-43B3-AB29-957BB759C6DF" restricted="1">
     <dc:title>(?) W9</dc:title>
     <res size="42949672950" duration="12:00:00.00" resolution="1046x576" bitrate="16000" av:pixelAspectRatio="1:1" protocolInfo="http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_EU_ISO;DLNA.ORG_OP=00;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=61
F00000000000000000000000000000">http://192.168.1.7:7522/upnp/channelstream/00084.ts</res>
   </item>
 </DIDL-Lite></Result>
       <NumberReturned>3</NumberReturned>
       <TotalMatches>3</TotalMatches>
       <UpdateID>1</UpdateID>
     </u:BrowseResponse>
   </s:Body>
 </s:Envelope>
00000000
