jErk` Posted April 9, 2010 Posted April 9, 2010 Hi, I'd like to introduce Xaeon, a (community powered) mash-up of Aeon, X-Skin and mymovies for the living room. See more screenshots or download the latest revision in your favorite resolution (1920x1080, 1280x720 or 1280x720lp which should scale on Atom 330+). The blabla: The very basic idea of Xaeon is to be a living room compatible media center skin. That said, you might notice the skin excludes some (imho) less important windows. Further the menus and buttons are reduced. I <3 DVBViewer for being soooo tweak-able but a living room skin has to be clean/strict not an egg-laying wool milk pig. While I don't want certain windows, you maybe do. That is where it comes to "community powered"... Everyone is encouraged to contribute! You see a bug, missing a template, have a better idea or know how to help an unskilled user? Do it! (.. and upload or mail me your results). I am missing this kind community work here sometimes; let's see how it works out. //Todo * MyMovies_details, correctly bind Play/Trailer/Back * Add missing / buggy XML templates * Create a forks (e.g. no-tvlogos) * Create a setup.msi to help new/unskilled users install & config all the components * ... If you contribute, please: * Respect copyright, see and update "!Copyright - License.txt". * Understand that yellow background with red font might not match the Xaeon style and is likely to be discarded. * Flag any transparency layer image with the description "imageAlphaFilter" (see 1920x1080 home.xml) * Flag any object that can be removed for performance optimization with a description starting with "xdisposable". (See "1920x1080" home.xml vs. "1280x720 Performance" home.xml). * Use fonts wisely, 1080>720 resize requires smaller fonts. If you feel like adding a new font, add at least two smaller subsequent sizes (see fonts.xml) I hope we'll have some fun (: /jErk` Quote
BALOU Posted April 10, 2010 Posted April 10, 2010 Webseiten für Download und Sreenshots sind nicht erreichbar. Quote
TVFreak Posted April 10, 2010 Posted April 10, 2010 (edited) Webseiten für Download und Sreenshots sind nicht erreichbar. Geth bei mir alles einwandfrei. Habs grad runtergeladen, und vorher auch mal durch die Vorschau geblättert. Okay habs grad nochmal mit dem IE probiert (benutze normal nur Firefox) und da macht der Popup-Blocker wieder mal was er will. Geholfen hat die EInstellung "Popups für diese Seite (DVBViewer.info) immer zulassen. Jetzt weiss ich auch wieder warum ich den IE nicht benutze.... Edited April 10, 2010 by TVFreak Quote
TVFreak Posted April 10, 2010 Posted April 10, 2010 Muss zugeben der Skin gefällt mir zwar, aber mehr interresierte mich die Integration vom MediaCenterMaster und das ist super. Habe testweise mal nen Film in den Standardeinstellungen mit der de.DLL importiert. Hat alles sofort geklappt. Der Titel wurde auch anstandslos in MyMOvies importiert. Für mich ein weiterer Stein auf dem richtigen Weg. Inzwischen sindmit MyMovies und MySeries quasi unverzichtbar geworden. Ich kann nur hoffen die DLL wird weiter gepflegt und an neue MyMovies Versionen angepasst (falls nötig). Quote
BALOU Posted April 10, 2010 Posted April 10, 2010 Geth bei mir alles einwandfrei. Habs grad runtergeladen, und vorher auch mal durch die Vorschau geblättert. Okay habs grad nochmal mit dem IE probiert (benutze normal nur Firefox) und da macht der Popup-Blocker wieder mal was er will. Geholfen hat die EInstellung "Popups für diese Seite (DVBViewer.info) immer zulassen. Jetzt weiss ich auch wieder warum ich den IE nicht benutze.... Na da weiß ich auch nicht mit Firefox,Opera und IE gehts hier nicht.Ist auch ein ganz frisches W7 System,also nichts rumgefuscht. Habe auch Firewall und AV Scanner deaktiviert und Popups zugelassen download von unterschiedlichen Rechnern alles ohne Erfolg. Quote
jErk` Posted April 12, 2010 Author Posted April 12, 2010 Hi TVFreak, Ich kann nur hoffen die DLL wird weiter gepflegt und an neue MyMovies Versionen angepasst (falls nötig). Wenn Dir, ausser dem MCM Bugs, etwas auffällt, sag Bescheid (; Gruß, jrk Quote
butchabay Posted August 12, 2010 Posted August 12, 2010 Habe seit langem nicht mehr reingeschaut, da tut sich doch was ... sehr schön umgesetzt den Aeon Skin von xbmc. Werde es gleich mal testen ... bis dahin ... danke. Quote
sw4y Posted October 4, 2013 Posted October 4, 2013 Ist zwar schon steinalt - ich habs aber gerade erst entdeckt. Skin sieht super aus, bleibt ab jetzt im Wohnzimmer! Danke dafür!! Quote
