Remote control for TT
bral
After couple hours of searching how to set TT remote control now i post the complete tutorial for newbies.
The new TT Remote Inputplugin can be found in the Membersarea -> section.
QUOTE
This Plugin enables you to use the remote controls of Technotrend cards directly with the DVBViewer Pro.
Installation:
- Extract the archive into the DVBViewer Pro plugin folder.
- Start DVBViewer und choose options -> Input -> Input Plugins
- You should see the "Technotrend remote" plugin in the plugin list.
- Activate it by checking the box in front of the plugin name.
- Select settings (button on the lower right). This shows the settings dialog of the plugin.
- In this dialog select the device you want to use. Leave the dialog by pressing OK.
- Now you can learn the remote keys in the "Input" section of the DVBViewer options.( Guest_Lars_MQ_*)
The manual isn't updated... nowadays to assign keybard key's to command you have to:
• go to "Settings / Options /Input"
• press the "Learn" button (it remain pressed until you click on it again...)
+ select the desired command
+ press a key (or combination of...) or a remote button
• repeat the above two + signed line for how many command you want associate/change
• click again on "Learn" to disable the learn session
• click on "Save" button & "Ok" and you are ready to go...
(as you can see you can also "Export" & "Import" the whole set or a subset of key/remote button assignment...)
...but you want a key to minimize DVBViewer that's not listed among the standard one's...
so you addictionally have to add a "special" command, i.e an "action"; do so:
• click on the list where you want to place a new "special" command
• click on "Add" button (you can also add a new group of command, just press "Add group" and name it...)
• give a name to the command (e.g. "Minimize" in you case)
• in the "Actioneditor" windows open the top right drop down list
• search and select "WindowMinimize"
• click on "Add" button (you can add more than one command in the same "action", for example you may want also add "Mute"...)
• click on "ok" button
• assing a key/remote button with the above procedure and you are ready to go...
...finally I'm guessing you need another command to restore DVBViewer:
now you know how to, the specific action is "WindowRestore"... ( Groxy)
regards
