stream from recordingservice problem
powericer
When im streaming from my recordingservice it lags all the time, sometimes once in a minute and sometimes longer between lag, but the picture freezes and in about 3 sec the stream starts again. i am using the latest
» Description: DVBViewer Recording Service ( 10071 Downloads )
» Version: Version 1.5.0.31 Beta
» Size: 1547 KBytes
» Last Updated: 18.08.09
and
» Description: DVBViewer ( 569356 Downloads )
» Version: V4.2.1
» Size: 6183 KBytes
» Last Updated: 25.07.09
Please say that someone have a solution
Best regards Johan
how do you stream, which network medium, did you sacrifice a virgin or at least an apple on full moon? You see how much question your posting leaves open. So scroll up on this page und read. ;)
hi again, imlearning ;) im using cable and have tried different routers and switches. and i have also tested on 2 other computers complete different with same results. i have no idea please say u have a solution
/johan
support_server.zip
support_client.zip
and im using the bulit in dvbserver in recordingservice...
Helloooo?? can someone help me????
Yes we can :biggrin: this:
» Size: 1547 KBytes
is not the latest version :) see there for the latest one.
  • 1 month later...
i have tried all new version, and no luck is there any help out there???
Thanks Johan
Impossible to say what is causing this. What makes you think this is especially related to Recording Service and DVBViewer? Have you checked if playing a movie with for example MPC-HC over your LAN at home (MPC-HC at client and movie at server) is smooth? Check both SD and HD material to see if there is a difference. If you experience lag with SD material as well, then you have to start troubleshooting networkcards, router, checking networkspeed etc. to start with.
Edited by majstang
most certainly its a network problem. Unless you have the same problems on the recording PC as well. Then its probably a problem with the TVcard(drivers) or the signal.
