streams to WD LIVE TV
I tried to make a WD LIVE TV streaming and stays black screen without leaving image.
What could be happening?
The same configuration with my PopcornHour A-100 is working properly.
Someone could try?
Thanks in advanced!
Which version are you using? support.zip?
I test DVBViewer 4.2.1 + Recording Service 1.5.0.31, with this version I get an error that can not play the content.
With this version DVBViewer 4.3.1.140 BETA + Rec. Service Test 1.5.0.105, black screen without leaving image
Right now I have no support.zip, I promise to send it soon.
  • 4 weeks later...
Hello again Lars, I leave the support.zip here. SVC and I upgraded to the latest version DVBViewer. The message I get is that you can not play the media. The same configuration with the PopcornHour works perfectly.
The error message in WD LIVE exactly said:
"Unable to play the selected file. Please refer to the user manual for a list of supported file formats."
I tried recording from the SVC, and then replay the recording perfectly from the SVC in the section DVBViewer Mediaserver / Video / Recordings / All
The media file is reproducible by the WD LIVE, the problem must be something in the MediaServer connection string that does not interpret correctly.
Thanks in advanced!
Edited by isabido
