dvbrewer Posted May 24, 2010 Posted May 24, 2010 (edited) The Microsoft H.264 decoder does not seem to like .mkv and .flv files so you often get stuttering, it would be good if you could use filetypes in the Auto B conditions for Video B in Direct X settings, so you can set another decoder such as ffdshow or MPC, thanks. Edited May 24, 2010 by dvbrewer Quote
Griga Posted May 25, 2010 Posted May 25, 2010 it would be good if you could use filetypes in the Auto B conditions for Video B in Direct X settings, It's already possible. Enter them (additionally to other conditions) with a preceding dot and separated by commas, e.g. .mkv,.flv This will let DVBViewer automatically switch to Video B if .mkv or .flv files are played. File extensions implicitely set the condition "file" for Video B and can't be inverted by a preceding /. The logic behind it: DVBViewer switches to Video B if Condition1 and Condition2 and... and (filetype1 or filetype2 or...) is true. Quote
sw4y Posted May 25, 2010 Posted May 25, 2010 Is it possible to use auto b for files except some special ones? as an example: use auto b for all files except .m2ts - so that m2ts files automatically are played with auto a option? or would it be possible to choose the codec especially for m2ts files so that all other auto b options remain untouched (use of reclock in auto b for smooth playback) - so that the file is played with auto b options just with another codec? Quote
Griga Posted May 25, 2010 Posted May 25, 2010 Is it possible to use auto b for files except some special ones? No. File extensions ... can't be inverted by a preceding /. Quote
dvbrewer Posted May 25, 2010 Author Posted May 25, 2010 It's already possible. Enter them (additionally to other conditions) with a preceding dot and separated by commas, e.g. .mkv,.flv This will let DVBViewer automatically switch to Video B if .mkv or .flv files are played. File extensions implicitely set the condition "file" for Video B and can't be inverted by a preceding /. Thanks for confirmation, another great feature discovered ! Quote
majstang Posted May 25, 2010 Posted May 25, 2010 Thanks for confirmation, another great feature discovered ! Yeah thanks! Had no idea about this one and these nuggets comes around from time to time when least expected. It would of course be easier for us who not speak German to know these things if having a complete DVBViewer Pro manual in English and not the joke which is in the Wiki right now. There are many moderators that both speak exellent English and have the knowledge, but nobody seems to be keen on taking on this task. Quote
dvbrewer Posted June 16, 2010 Author Posted June 16, 2010 It's already possible. Enter them (additionally to other conditions) with a preceding dot and separated by commas, e.g. .mkv,.flv OK, it seems that if I have this set, I cannot select Video Output B while watching H.264 HD TV- is this intended or a bug? Quote
dvbrewer Posted January 31, 2012 Author Posted January 31, 2012 OK, it seems that if I have this set, I cannot select Video Output B while watching H.264 HD TV- is this intended or a bug? Bump, problem still exists, also for MPEG2 TV. Quote
Tjod Posted January 31, 2012 Posted January 31, 2012 File extensions implicitely set the condition "file" for Video BSo you can't switch to Video B during TV playback. Quote
dvbrewer Posted January 31, 2012 Author Posted January 31, 2012 So you can't switch to Video B during TV playback. OK, thanks for explanation. Quote
Tjod Posted January 31, 2012 Posted January 31, 2012 You can use a GraphPreset instead of the Video-B. http://www.DVBViewer.tv/forum/topic/46961-DVBViewer-pro-49/ http://www.DVBViewer.tv/forum/topic/46975-graph-presets-einfacher-editor/ http://de.DVBViewer.tv/wiki/GraphPresets Quote
