majstang Posted June 3, 2010 Posted June 3, 2010 Despite unchecking: Configure-->Recordings - Create Information file - Save EPG as fileinfo - Write Log - Write extended log file is inactivated and: Webinterface-->Configuration-->Recorder - Create EPG information file - Save EPG as fileinfo - Create Log file - Extended Logging (format informations) the log file still shows up during "some" recordings. Not every recording though. What have i missed here? Is there some setting or some ini file to edit to get rid of the log file all together?
Lars_MQ Posted June 3, 2010 Posted June 3, 2010 These settings are saved per timer, so only new timers will not have this option set.
majstang Posted June 3, 2010 Author Posted June 3, 2010 These settings are saved per timer, so only new timers will not have this option set. Ah, of course...silly me not getting that Even though i still not get the point in having it that way...thanks Lars!
