NedZha Posted June 3, 2010 Posted June 3, 2010 I planned to replace my skystar 2 with a new skystar HD2 and look what happend. the new card makes a strange annoying noise right when I change to every DVB-S2 channel. I'm really confused and can't really figure out whether it's a normal behavior of the hardware or my card is a fake? can one of the owners confirm anything, please? it's very bad headache right now and I'm so close to throwing it out of the window! Quote
skeal Posted June 3, 2010 Posted June 3, 2010 sadly normal ... my two cards do the same... many other told same behaviour Quote
NedZha Posted June 3, 2010 Author Posted June 3, 2010 (edited) it's was just yesterday when I realized I had found a good PC DVB card vendor to that I would remain a constant customer over years and centuries! what a shame this cruel world ruin your dreams in just a blink of eye. btw, DVBViewer detects it as a HID device not a regular BDA or NIC adapter (Exactly "TechniSat Mantis DVBS BDA Receiver ") and I need to check "Is DVB-S2" manually; is that a problem? what's the meaning of Mantis? Edited June 3, 2010 by NedZha Quote
Wintermute77 Posted June 7, 2010 Posted June 7, 2010 There's no noise whatsoever coming from my SSHD2. Totally quiet piece of HW. I should consider myself lucky perhaps :-) btw, DVBViewer detects it as a HID device not a regular BDA or NIC adapter (Exactly "TechniSat Mantis DVBS BDA Receiver That's normal (same here). DVBViewer actually detects and access the card as BDA device. Mantis is driver name by Twinhan, where SSHD2 is basically Twinhan product marketed under different name by Technisat and runs with customized Twinhan Mantis driver. The HID device you're refering to would probably be Infrared/Radio remote control. Quote
Dj_Jelak Posted June 30, 2013 Posted June 30, 2013 I also have skystar hd2, and strange pitch noise at hd channels, but only at V polarity, at H no strange noise on hd channels. I try my card in next pc, different motherboard, and there is also noise but no so high. So my guess is that have to do something with tuner. Quote
Uukrul Posted July 1, 2013 Posted July 1, 2013 No strange sounds from my HD2. Maybe an issue with newer cards? (mine has 4 years) Quote
Uukrul Posted July 1, 2013 Posted July 1, 2013 A bit of off topic to all of you with this card: Can you see the signal quality with the TransEdit TS Analyzer and the HD2? I always get 0% with the HD2 but with a DVB-T usb dongle works fine. Quote
