Mach5 Posted June 6, 2010 Share Posted June 6, 2010 Hi, Playlist feature is very used and important in my installation cause my kid is watching short mpg-files. This feature has worked but can't figure out why it stopped working few months ago. Problem occurs only when playlist has mpg-files. Next entry is not started automaticly. All those few option are tested and no luck to fix this. Could someone comfirm that this should work on my installation as well? In mp3-files playlist is working correctly. Not sure when this problem started so I'm not able to pinpoint update or change related to this issue. Or maybe I have done something but not able to fix it back anyway. Br, Mach5 support.zip Quote Link to comment
Mach5 Posted July 25, 2010 Author Share Posted July 25, 2010 When changing Video Renderer back to Overlay Mixer playlist is working normally also with mpg-files. When choosing WM7, WMR9 or EVR next playlist entry isn't working as it should in my setup. Quote Link to comment
