dvbviewer ?
martinakis
How to enlarge the names on tv channel on channel list in DVBViewer ?
just click channel editor in the channel list menu and in the upgoing window make a slow dopple click at the channel you lke to "enlarge"
When I click slow double on the channel I can only write the channel name with a capital letter, but it is not enough,because I watch tv on plasma tv.
This should work as long as you have not used the tweak <entry name="D3DExclusive">1</entry> in the DVBViewer's setup.xml.
How do you bring up the Zappi window?
I would recommend these settings:
Options -> Advanced -> [x] Ignore everything at full screen
Options -> General -> Ctrl + Shift + z [x] Hotkey (show/hide)
[x] Right mouse button delay (show/hide)
And maybe you have to enable [x] Apply Win7 Fix (requires restart) in the Advanced Options.
And don't forget to push the "Save"-Button. ;)
If this does not work for you, it would be better to discuss this in the Zappi-Thread.
