Skyserfer Posted June 16, 2010 Posted June 16, 2010 Help me, I can not download anything from the Members Section! I recently bought DVBViewer. I have received the password to log in Members Section on my mailbox. I enter the Members Section normally, but I can not download anything from there. I enter the password and nothing happens. With this problem I consulted "http://DVBViewer.com...x.php?page=lost" and received a reply: "For activation we need prename and surname". But while buying I had forgotten to specify prename and surname . I informed "http://DVBViewer.com...x.php?page=lost" about my mistake and provided them with the data (prename and surname) for the activation of the program. There is no answer. What should I do ??? Quote
Lars_MQ Posted June 16, 2010 Posted June 16, 2010 which browser are you using? Try firefox instead of IE to log into the membersarea. Quote
Skyserfer Posted June 16, 2010 Author Posted June 16, 2010 I tried to use Opera, IE8, FireFox but it did not help... Quote
mazeus Posted August 10, 2010 Posted August 10, 2010 Yh ithink its a scam i cant login either all they do is send username and pass word but its useless. gonna try get my money bak from PP. Quote
hackbart Posted August 10, 2010 Posted August 10, 2010 There is nothing which can't be solved by contacting us directly, if you are a regular user. The members section works fine under FireFox, Chrome, IE and Opera (which i use since years). Christian @Skyserfer: It would be fair enough if you would drop at least an information that you got it working, especially since I can see your downloads in the log file Quote
