pariskypict Posted July 14, 2010 Posted July 14, 2010 Hello sorry for my bad English. It's my first post because the search function does not return a response on my problem. Often the software shuts itself and generates an error report windows which I just read: AppName: DVBViewer.exe AppVer: 4.2.1.0 ModName: ivaudio.ax ModVer: 8.0.6.109 Offset: 00014944 I have no idea where the problem may come. And you ? Thank you. I have windows XP sp2 With Cam Hauppauge wintv Hvr4000 and CyberLink for video codec and Intervideo for audio codec Quote
desweil Posted July 14, 2010 Posted July 14, 2010 obviously the audio codec(ivaudio.ax) is the problem. Use a differnet audio decoder. AC3 filter or ffdshow are good. Quote
sw4y Posted July 14, 2010 Posted July 14, 2010 try another audio codec (for example ac3 filter -> google), ivaudio.ax is part of windvd/intervideo and seems to cause trouble. therefore try another one. Quote
pariskypict Posted July 15, 2010 Author Posted July 15, 2010 Thank you for your reply. I installed the AC3 Filter Pack and yet I have no error. Quote
