dvbviewer quits after hd zap (riproducible)
toblerone
hello, latest DVBViewer beta+recording service (but there was with the stable as well if i don't wrong)
zapping from an dvb-s2 channel to the suissehd DVBViewer quits, no problem if the zap start from a dvb-s channel (tested many times)
the same if starting from suissehd i go to a dvb-s2 channel: DVBViewer quits, no problem if i go to a dvb-s channel
no problem switching between other dvb-s2 channels
forgot to say:
xp sp3 (fresh installed os) on amd 5200 + asus m3a + 2gb ram + geforce 8500gt (latest nvidia driver)
codec: coreavc dscaler5 ac3filter
card: hauppage hvr-4400
Edited by toblerone
tested with ffshow as h-264 codec and DVBViewer does not quits: i can change channel but from/to suissehd i have only the audio if i use another dvb-s2 chan (same as before, but this time i have not the DVBViewer quit, so i can zap to other channels)
for have back the working video i need to use a dvb-s channel
Edited by toblerone
any further suggestion?
i have tried to remove all the plugins that i can remove (netstreaming, installed but not used and importcsv) but nothing change
the problem:
zapping to hdsuisse (from or to a dvb-s2 channel, no prob with dvb-s) or crash DVBViewer.exe (with coreavc) or the video desappears (ffdshow) until i zap on a dvb-s channel, then i can zap without problem to every channel but NOT hdsuisse or the issue come back and i need to zap to a dvb-s
seems that the codec is not restarted at channel change but the different format make crazy the codec+DVBViewer:
if i use ffdshow and zap from hdsuisse to a dvb-s2 the video desappears but i have the audio, but if i enter in the directx option then i change the h264 codec the video start correctly
thanks in advance
YuHuuu someone here?
is needed to test all the codecs around???
i don't like it
but only one works, all the rest 5 that i had tried fails changing to/from it
maybe is really a bug
just for say that that issue is present as well with the rc1 and the usual h264 codec :(
I don't undestand what you are doing there sorry
If your used plugin makes trouble, the only way is this:
..try without any plugins
If you have trouble without the plugins you have to upload a new support.zip, OK?
just for report it
tested as well with a clean os and same config/codecs as the opening thread: was 'cuda'
enabling it i had that prob disabling it all fine
