Wrong text in OSD messages
zamolxis
For some reason, some of the OSD messages no longer work properly here. For example, when trying to delete a recording when asked "Do you want to delete..." instead of "Yes" is displayed "5" and instead of "No" I get "6".
If I go to "What's now" and I select one of the tv shows in the list for the red button I get "911" for the green I get "210" for yellow "209" for blue "7" instead of any words! etc.
I tried uninstalling/reinstalling DVBViewer, but no luck - it's still the same ...
Any ideas?
Thanks,
Tibi
Looks like the language file is missing or corrupt \DVBViewer\Language\English.lng.
I erased that file and reinstalled DVBViewer - still the same results. If I switch to Spanish for ex. it works fine.
It seems to me the problem is with the English.lng file in the configuration folder. Whenever it gets created it doesn't look fine in notepad. No [osd] section?
Do you mean the one in the configuration folder? I only deleted it after I noticed the problem - and it is automatically created again - but it seems to me not correctly - it's not identical to the english.lng in the program files folder.
I downloaded, uninstalled and reinstalled again DVBViewer, but I continue to have the same problem. Maybe the english.lng file in the actual setup package is corrupt? Since reinstalling hasn't changed anything...
