Stream to port 3335 not working in new beta
horndrup
I have installed the new beta 1.6.5.1 and now I can't stream on port 3335, it worked before with the old versions. When I look in the svcdebug.log file I can see the command for VLC, it look like this :
C:\Program Files (x86)\VideoLAN\VLC\vlc.exe -Idummy --no-sub-autodetect --verbose=0 --dummy-quiet --no-stats --sout-transcode-threads=2 "http://192.168.2.10:7522/transcode/channelstream/22.ts?id=192.168.2.2" :sout=#transcode{vcodec=mp2v,vb=1024,scale=1.00,acodec=mp2a,ab=128,channels=2}:http{mux=ts,dst=:3335/}
When I execute the command in a command prompt nothing happens, but when I change the command to this : "C:\Program Files (x86)\VideoLAN\VLC\vlc.exe" -Idummy --no-sub-autodetect --verbose=0 --dummy-quiet --no-stats --sout-transcode-threads=2 "http://192.168.2.10:7522/transcode/channelstream/22.ts?id=192.168.2.2" :sout=#transcode{vcodec=mp2v,vb=1024,scale=1.00,acodec=mp2a,ab=128,channels=2}:http{mux=ts,dst=:3335/} the stream works again.
Is this a bug in the new beta ?
Anything new on this ?
OK work around for now: in the service options program set the vlx.exe path and filename and after that manually enclose it in " this should work I think.
I tried that before I wrote the first post, but it did not work. The program removes the ". I also tried adding " in the service.xml file, but with the same result.
sh*** :( OK I'm doing an small update tomorrow. :)
Do you have any date for the small update ?
The stop streaming button does also not work in de webbased site. The VLC.exe is still in working in the background.
something new about the update
Yes, some other problems were discovered and one of them was in the installer. We're testing it currently and hopefully tomorrow I'll upload the update.
The update is in the new membersarea. :)
Sorry to say, but it dosen't seem to work. I have tried a complete uninstall of RS and DVBViewer, and then I installed RS 1.6.0.6 and DVBViewer 4.2.1 and then it worked again. The VLC version was 0.8.6i. After that I installed RS 1.6.5.2 and DVBViewer 4.5 RC2 and then the stream to port 3335 failed again.
The svcdebug.log looks like this :
04.10.10 20:42:10.074 TUCCommandClient Release Hauppauge SMS1000 DVB-T Tuner
04.10.10 20:42:10.074 TUCCommandClient Destroy Hauppauge SMS1000 DVB-T Tuner
04.10.10 20:42:11.086 TUCCommandClient Destroyed Hauppauge SMS1000 DVB-T Tuner
04.10.10 20:42:11.086 Releasereference CmdClientDisconnect: 1
04.10.10 20:42:15.434 VLC "C:\Program Files (x86)\VideoLAN\VLC\vlc.exe" -Idummy --no-sub-autodetect --verbose=0 --dummy-quiet --no-stats --sout-transcode-threads=2 "http://192.168.2.10:7522/transcode/channelstream/22.ts?id=192.168.2.2" :sout=#transcode{vcodec=mp2v,vb=3072,scale=1.00}:http{mux=ts,dst=:3335/}
04.10.10 20:42:16.367 VLC VLC media player 0.8.6i Janus
04.10.10 20:42:16.367 VLC [00000298] dummy interface: VLC media player - version 0.8.6h Janus - © 1996-2008 the VideoLAN team
04.10.10 20:42:16.367 VLC Warning: if you can't access the GUI anymore, open a command-line window, go to the directory where you installed VLC and run "vlc -I wx"
04.10.10 20:42:16.367 VLC [00000298] dummy interface: using the dummy interface module...
04.10.10 20:42:16.490 VLC [00000312] main private error: no sout stream module matched "http"
04.10.10 20:42:16.491 VLC [00000309] stream_out_transcode private error: cannot create chain
04.10.10 20:42:16.491 VLC [00000308] main stream output error: stream chain failed for `transcode{vcodec=mp2v,vb=3072,scale=1.00}:http{mux=ts,dst=:3335/}'
04.10.10 20:42:16.491 VLC [00000307] main input error: cannot start stream output instance, aborting
04.10.10 20:42:16.698 VLC [00000294] main playlist: nothing to play
use the current vlc as stated in the changelog.
I have done that and the svcdebug.log don't have the error anymore, but stream is still gone. VLC 1.1.4 on the client computer can't play the stream.
works like a charm here.
great, but what about me. It works when I manually type the command in a command prompt.
Edited by horndrup
i have same problem streaming not working only direct connection working
I can confirm that transcoding to port 3335 work like a charm also here (and what a incredibly fast channel change, many thanks Lars! :biggrin:), also to an old SmartPhone HP HW6500...
I've installed, on my RecordingService PC, the VLC 1.1.4 SelfExtracting Package, allowing it to delete all preferences and cache (...perhaps this is a needed trick...)
:bye:
I got the same problem, with DVBViewer 4.5 and Recording Service 1.6.5.2 can't use transcoding on port 3335, direct streaming on 7522 works just perfect but not transcoding.
I have tried to uninstall DVBViewer, Recording Service and VLC play, but with no luck.
Is their any chance that we can have the old version back? cause this is really annoying.
I think there is a problem with the new version of RS 1.6.5.2.
If I look in this tread and the treads below, I can see that others are having the same problem like me. Streaming to port 3335 dosent work anymore. If I downgrade to older versions it works again.
I have reinstalled my computer. Installed DVBViewer 4.5 and then RS 1.6.5.2 and VLC 1.1.4. Direct streaming works but not to port 3335. I have also deactivated my firewall but with no success.
http://www.DVBViewer.tv/forum/topic/42873-older-version-of-recording-service/
http://www.DVBViewer.tv/forum/topic/42732-vlc-not-play-in-web-interface/
http://www.DVBViewer.tv/forum/topic/42844-streaming-funkt-nicht-mehr/
Any news on the above reply
No, sorry but it works for me Nobody could provide till now a reproduceable case for me and I don't know where to look, cause as I said it works here...
Have you tried a clean computer and then installed the programs in the way that I did. The strange thing is that it works with older versions. And it works when I type the command manually in a command prompt.
Okay, seams i had same problem. direkt streaming is okay, but nothing with VLC on Port 3335. so i tested little things.
1 start webinterface on htpc - okay
2 start direkt-streaming on htpc - okay
3 start streamin with vlc port 3335 on htpc - okay
4 start a second instance of vlc on htpc to show stream --- OKAY
------------ so the DVBViewer part is okay i think -----------------
5 start VLC on Client to show stream - nothing
6 deactivate on both PC (htpc and client) the windows Firewall -- nothing
so at the end i think streming is okay, but something on win7 blocked. don't no what else i can do to find out.
Okay now it works. It was Windows Firewall.
Edited by TVFreak
  • 1 month later...
Latest DVBVService_1.6.8 still doesn't play in web interface (firefox don't start straeam via embedded vlc plugin, starting extarnal stream with vlc.exe is ok)... ff:3.6.13, vlc:0.8.6f + 1.1.5 to no avail
Downgrade to DVBVService_1.6.2.3 and to vlc 0.8.6f, then playing doesn't on my windows any problem.
Josef
  • 1 month later...
Now I finally got it working to stream on port 3335. I have tried all the updates and non of them worked. I have checked the firewall and even disabled it but with no success.
But then I tried to run the Recording Service with a different account instead of the "Local system account", and now its working.
Is this a bug ?
Maybe some VLC Player files are in the VirtualStore from Windows and so only present for one user account.
I don't think that is the case. VLC are installed where there is no virtualstore. Before when I ran the Recording Service with the Local system account I could see in my taskmanager that VLC was running fine under the Administrator account ( the logged on user ), but there where no stream. But now when I also run the Recording service under the Administrator account it's working.
If I install a older version of Recording Service ex. 1.6.2.3 the streaming workes fine the the Local System Account, so what has changed ?
Hi. I used the Port 3335 to but the Win7 firewall makes me crazy. Please tell me the settings to use the port over the firewall. when i open the firewall it works.
Edited by masterburner
Hi. I've just tried with the newest viewer and RS and still it will not stream through port 3335. Firewall and so on are turned off on both computers. Hope for a solution soon as I'm going on holiday in one month.
Installed the new vlc 1.1.7 player on the server (had been running the old 0.8.6i) now everything is working.
  • 3 weeks later...
Everything has been working nice until yesterday
Norton internet security 2011 decided that DVBVservice.exe vas a threat and removed it to quarantine
I restored it and everything looks ok but now i cant use webstream any more :(
my svcdebug.log looks like this
26.02.11 11:32:08.105 AddReference webserver: 1
26.02.11 11:32:22.339 VLC "C:\Program Files\VideoLAN\VLC\vlc.exe" -Idummy --no-sub-autodetect --verbose=0 --dummy-quiet --no-stats --sout-transcode-threads=2 "http://192.168.1.72:7522/transcode/channelstream/1.ts?id=192.168.1.95" :sout=#transcode{vcodec=WMV2,vb=1024,scale=0.50,acodec=mp3,ab=96,channels=2}:http{mux=asf,dst=0.0.0.0:3335/}
26.02.11 11:32:53.214 ReleaseStandbyblock webserver
26.02.11 11:32:53.214 SetThreadExecutionState 0x80000000
26.02.11 11:32:53.214 Releasereference webserver: 0
26.02.11 11:32:56.402 SetStandbyblock webserver
26.02.11 11:32:56.402 SetThreadExecutionState 0x80000041
26.02.11 11:32:56.402 AddReference webserver: 1
26.02.11 11:33:26.464 ReleaseStandbyblock webserver
26.02.11 11:33:26.464 SetThreadExecutionState 0x80000000
26.02.11 11:33:26.464 Releasereference webserver: 0
I am using vlc 1.1.7
Edited by Tottes
  • 8 months later...
this post is awsome:
http://www.DVBViewer.tv/forum/topic/42476-stream-to-port-3335-not-working-in-new-beta/page__view__findpost__p__325863
The only way for me, with DVBViewer 4.9, and rec service 1.9.2 beta to watch embedded stream, or stream with 3335 port,
it changing user account to my user, or to administrator, but not let it set to local system account.
