DaUltimateTrooper Posted September 29, 2010 Posted September 29, 2010 Hey everybody, I installed the DVBViewer 4.2.1.0 and it works very nicely. I bought this software because I want to sack my DM800. I want to build a new system for gaming, movies and TV; all in one. I managed to get my configuration from my DM800 and set it up for DVBViewer. Everything works fine but some channels do not have sound. I tried changing the DirectX Audio settings (decoders etc )but I only managed some blue screens and nothing more. I don't know what could be the problem. I mean the DM800 can decode the sound. I do not know why the DVBViewer cannot. My computer is running: Vista Ultimate 64-bit Gigabyte PS700 DVB-S TV-Card Any ideas as to where to look for a solution? Log files or anything? I need some hints! Thank you in advance! Quote
desweil Posted September 29, 2010 Posted September 29, 2010 need support.zip (see link above) What channels have no sound? Is there a ac3 symbol in infobar? Try "ac3filter" as audio decoder, at least for ac3. Quote
giangi007 Posted September 29, 2010 Posted September 29, 2010 I have the same problem for (at the moment) 2 channel, Nickelodeon +1 Italia and Nickelodeon +1 Italia; this channel is normal channel (not HD), but i don't have sound. attacched support.zip and photo for the dvbsource. Thanks support.zip Quote
DaUltimateTrooper Posted September 29, 2010 Author Posted September 29, 2010 need support.zip (see link above) What channels have no sound? Is there a ac3 symbol in infobar? Try "ac3filter" as audio decoder, at least for ac3. desweil you nailed it man! I did not see any ac3 symbol on the infobar. It was actually mono mpeg2. Anyways I followed your advice and installed ac3filter. I started DVBViewer and everything worked with no further action. Thanks man! Quote
