toblerone Posted September 30, 2010 Share Posted September 30, 2010 notified on the same pc that runs the recording service and DVBViewer: from the rc1 as well with the previous recording service is not possible make the channel scan (only one transponder after the first successfully without.firewall.scan or worst no results at all before.deactivating.firewall) until the xp firewall is disabled after the scan all fine re-enabling the firewall i notified it tring a scan with a never used satellite if i don't wrong with the versions before the rc1 was possibile, but no sure about it obv i have the DVBViewer exceptions enabled (and allow.exception "master tag" is enabled) in the xp firewall, and is the only firewall on this pc regards Quote Link to comment
