B2C2 filter Audio/Video Ctrl. Interface ,Error !
rshd
Hello , :)
I have SkyStar USB PVR box with DVB driver 4.2.10, the, my OP is W2003 server , the signal quality is 49% , when I double click on any channel this MSG appear : :blink:
(cannot locate B2C2 filter Audio/Video Ctrl. Interface, error 0x91000101 , this probably cause by wrong tuner setting and /or the trial to tune encrypted channel ),
the channel I choose is not encrypted !!
what's the problem and the solution
thanks in advance :D
Make a channel scan and let us know which stations you can find.
Hello , Klausing ,
I deleted all channels , i do new scan for Arabsat2A SAT , it find nearly all the channels, when choosing anyone that error msg. appear. :)
Edited by rshd
I belive w2003 server is your problem. You must use it like a workstation. A server is not realy a multimedia system :)
Maybe the new driver 4.2.11 would help you.
Guest DAvenger
Didn't make DVBViewer to work on Win2003 in 2 months. I gave up :)
well , i am goging to try it in Win XP or W98, then i will post the result here.
Thanks. :)
It now work ok ,i do nothing just restart the server , i see the channels fine.
Many thanks :)
i know where was the problem , i run setup4pc then i run DVBViewer which cause the problem , when i run the DVBViewer only it work fine .
I use WinXp and After 20 to30 minutes i have the same Problem. Setup4PC is closed or opened. It makes no different. If someboddy could help so write your meaning
  • 3 weeks later...
hello
i have got the similar problem like RSHD, but on winxp
i've got signal about 60%, dish on hb
i don't have any image
only cannot locate B2C2 filter Audio/Video Ctrl. Interface...
but this one is weird:
my skystar2 finds every program on hotbird! even epg on some programs.
but i can't watch any programs even uncrypted
after copying the patch problem still remains
not only in DVBViewer bat also in progdvb and skyview
Maybe there is something wrong with my card
Have you tried to add some other MPEG decoder?
The better solution is to install a DVD player's sw that came with a decoder especially built for your pc's video card, eg. NVDVD if you have a NVidia, or ATI DVD Player if you own a ATI; normally you can find it in the video driver's CD...
Alternatively you can install other DVD player, like WinDVD (that add Intervideo codecs) or PowerDVD (that add Cyberlink ones)...
Remeber also to reinstall the last version of DirectX whenever you change something (hw or sw) relate to multimedia...
Good luke
Gioxy
