Kurtis Posted October 6, 2010 Share Posted October 6, 2010 http://img80.imageshack.us/i/14243346.png/ My config: My config: win 7 64 bit MB ASRock M3A770DE CPU AMD Phenom II x2 555 Black edition AM3 ( working on 4 cores ) CPU cooler Artic-Cooling Freezer 64 Pro RAM Sil. power 2x2 GB DDR3 1333 mhz VGA ATI Radeon Sapphire HD 5850 1GB DDR 5 HDD SATA II 1000 GB WD Caviar Black, 7.200 rpm, 32MB, WD1001FALS HDD SATA II 1000 GB WD Caviar Black 6 Gb/s, 64 MB, 3,5", 7.200 rpm, WD1002FAEX LC Power 650w Silent Giant AverMedia DVB-T Trinity Case Gigabyte GZ-X6 black For my graphic card -- Catalyst verison- 10.8. Chipset AMD 770, AMD K10 "Try a different decoders for Mosaic and PIP. Options > Picture in Picture Options > Mosaic preview " I tryed. No help http://img834.imageshack.us/i/59141234.jpg/ None of this is working. PiP is working ok. support.zip Quote Link to comment
Derrick Posted October 6, 2010 Share Posted October 6, 2010 ..try with TV/Radio Pre-Format Detetection. Quote Link to comment
Tüftler Posted October 6, 2010 Share Posted October 6, 2010 Make it shure that Cyberlink Decoder is working as MPEG2 Decoder and at TV playback decoder is in using >View >Filters (black marked entry)! You have an Directshow problem, use the forum search function and RadlightFiltermanager to correct the problem! In most case that is a codec pack problem but in Win7 Microsoft Decoder have an higher priority for decoder using, i think (i've none Win7 sys installed). Quote Link to comment
Kurtis Posted October 6, 2010 Author Share Posted October 6, 2010 ..try with TV/Radio Pre-Format Detetection. How can i do that ? Quote Link to comment
Kurtis Posted October 6, 2010 Author Share Posted October 6, 2010 Make it shure that Cyberlink Decoder is working as MPEG2 Decoder and at TV playback decoder is in using >View >Filters (black marked entry)! You have an Directshow problem, use the forum search function and RadlightFiltermanager to correct the problem! In most case that is a codec pack problem but in Win7 Microsoft Decoder have an higher priority for decoder using, i think (i've none Win7 sys installed). Cyberlink decoder is in use. But when i go to view/filters, nothing happens ! When i click, i get nothing- i have no black check mark. No confrim that i pressed anything. I only get some status windows in whic i cant change anything. http://img176.imageshack.us/i/45964333.jpg/ http://img291.imageshack.us/i/66423822.jpg/ Rad light Filter manager ? How can i manage this ? Quote Link to comment
Derrick Posted October 6, 2010 Share Posted October 6, 2010 How can i do that ? Quote Link to comment
Tüftler Posted October 6, 2010 Share Posted October 6, 2010 Cyberlink decoder is in use. But when i go to view/filters, nothing happens ! When i click, i get nothing- i have no black check mark. No confrim that i pressed anything. I only get some status windows in whic i cant change anything. http://img176.images...i/45964333.jpg/ http://img291.images...i/66423822.jpg/ Rad light Filter manager ? How can i manage this ? Ever heard of google? -> http://www.videohelp.com/guides?tools=454&&archive=%25 Only what is listed in >Filters is actualy working! In your case work the ATI MPEG Video Decoder and this decoder is shit, see mosaic! Quote Link to comment
Kurtis Posted October 6, 2010 Author Share Posted October 6, 2010 @ Derrick No help @ Tuftler Yeah, i know what is google. Your grammar is wrong, so it is quite difficult to understand you. I saw that someone had under the PLUGINS "Rad light Filter manager". I copyed the R.L.F.Manager files into PLUGIN folder, but nothing happend. Quote Link to comment
Tüftler Posted October 7, 2010 Share Posted October 7, 2010 @ Tuftler Yeah, i know what is google. Your grammar is wrong, so it is quite difficult to understand you. Because english isn't my native language and i have much to learn. I hate the grammar! I saw that someone had under the PLUGINS "Rad light Filter manager". I copyed the R.L.F.Manager files into PLUGIN folder, but nothing happend. Just start an how-to-thread for setting the priority of decoder with RadlightFiltermanager or use Google search! Quote Link to comment
