solo Posted October 6, 2010 Posted October 6, 2010 Hi, I have downloaded the latest DVBViewer but i cannot select the key or enter my username or password, is there any instructions to load this programme, I'm running Win 7. Thanks Brian. Quote
Griga Posted October 6, 2010 Posted October 6, 2010 More detailed please. Which file have you downloaded from where? Quote
solo Posted October 6, 2010 Author Posted October 6, 2010 More detailed please. Which file have you downloaded from where? I down loaded DVBViewer Pro 4.5 from the members area, but i cannot install it, what i want to know is how to select the key so i can put in my details so it will install. brian. Quote
Tjod Posted October 6, 2010 Posted October 6, 2010 If you enter the data once e.g. at the DVBViewer RC installation. You do not need to enter it again. If you like to check the data run the KeyTool. Quote
solo Posted October 7, 2010 Author Posted October 7, 2010 If you enter the data once e.g. at the DVBViewer RC installation. You do not need to enter it again. If you like to check the data run the KeyTool. Hi, it opens a dialogue box and it says key is missing, and i cannot enter my details, what i want to know is where is the key, is it D/L with the app. Thanks. Quote
Griga Posted October 7, 2010 Posted October 7, 2010 The installer (setup.exe) should prompt for credentials. Didn't it? If it didn't, launch KeyTool.exe. Quote
TVFreak Posted October 7, 2010 Posted October 7, 2010 i cannot enter my details, First, after you started KeyTool, you have to load your KeyFile in Keytool. After that you can type in your personal Data like User an Serial. The Keyfile was send as Attachment with the Userdata-Email. Open Email and save KeyFile!! Open Keytool and load it from the location you saved it. Quote
solo Posted October 7, 2010 Author Posted October 7, 2010 The installer (setup.exe) should prompt for credentials. Didn't it? If it didn't, launch KeyTool.exe. Hi, yes it asked for credentials, but it says keyfile is missing, so i cannot put my details in. what i want to know is where is (what is)keyfile. Brian Quote
Griga Posted October 7, 2010 Posted October 7, 2010 Read this: http://www.DVBViewer.tv/forum/topic/42222-how-to-get-new-credentials/ Quote
solo Posted October 7, 2010 Author Posted October 7, 2010 (edited) First, after you started KeyTool, you have to load your KeyFile in Keytool. After that you can type in your personal Data like User an Serial. The Keyfile was send as Attachment with the Userdata-Email. Open Email and save KeyFile!! Open Keytool and load it from the location you saved it. Hi, i have saved keyfile to a folder on my desktop, but i cannot load it into keytool. how do I load it to keytool, i cannot open it. In keytool it says keyfile missing. Brian Edited October 7, 2010 by solo Quote
TVFreak Posted October 7, 2010 Posted October 7, 2010 how do I load it to keytool, i cannot open it. Please open the Link from Griga and read section "How to Use the Key Tool". I can't explain it better!! Quote
solo Posted October 7, 2010 Author Posted October 7, 2010 Please open the Link from Griga and read section "How to Use the Key Tool". I can't explain it better!! Thanks for all your help I got it to work at last. Brian. Quote
Yury72 Posted October 8, 2010 Posted October 8, 2010 Good afternoon! Somebody can answer me Why I can't come in DVBViewer.tv/members Under the password? Here http://www.DVBViewer.com/en/index.php?page=lost I have already written two times Without the answer. Quote
ElecardFAN Posted October 8, 2010 Posted October 8, 2010 Probably because there are a lot of others who are also to dumb to read the "how to get the new credential" post from griga. Sorry if you are unable to type the key in the input box you need either learn how to type, or use copy&paste. Quote
dvbrewer Posted October 8, 2010 Posted October 8, 2010 I have already written two times Without the answer. Read here, a new password & members area system is in operation so you need to register for a new password. Quote
Yury72 Posted October 8, 2010 Posted October 8, 2010 (edited) Read here, a new password & members I have already received the new password... Also has loaded and has established the version 4.5RC1 But When was there was final version 4.5 I can't enter in DVBViewer.tv/members Under the new password... Edited October 8, 2010 by Yury72 Quote
Tjod Posted October 8, 2010 Posted October 8, 2010 What happens exactly if you try to open https://www.DVBViewer.tv/members/ ? What browser are you using? Quote
Yury72 Posted October 8, 2010 Posted October 8, 2010 The browser an opera and internet explorer There is no access. Quote
Tjod Posted October 8, 2010 Posted October 8, 2010 And you have downloaded 4.5RC1 with the same data? Then I have only one idea. If you have distributed your username/password or files from the Members Section your account may be blocked. Quote
Yury72 Posted October 8, 2010 Posted October 8, 2010 I name/password Showed to nobody. It is blocked can not. ... If it has occurred, I can receive the new password? Quote
Tjod Posted October 8, 2010 Posted October 8, 2010 If a user is blocked e.g. for sharing files from the Members Section for sure he will not get a new password. But if a user is blocked, it can't be checked from someone here in the forum for which reason or if something else is wrong with his account. You have to write an email to the address from here http://www.DVBViewer.com/en/index.php?page=lost but better wait until Monday. Quote
Yury72 Posted October 8, 2010 Posted October 8, 2010 (edited) Thanks Has written there Edited October 8, 2010 by Yury72 Quote
Yury72 Posted October 11, 2010 Posted October 11, 2010 What to me to do? Access isn't present... Quote
kobe8 Posted October 12, 2010 Posted October 12, 2010 Hi!! I have not received yet the second e-mail to validate new credentials since september 20. I have also checked the spam. How could I proceed? Thanks and regards, Quote
