Video too late
rapper
Hi
My prob is a general one. When I switch to a channel on my analog tv, for example RAI 1, and then I switch to the same channel on DVBViewer, the video on my PC is somehow LATE (about 3 sec.). So there is a differnce in time.
I even tried REAL TIME priority, but this doesn't solve the problem. On a real SAT Reciever the difference is about 1 sec.!! Why the SS2 is slow :)
Thanks for answer :D
The driver latching some data before you see it. Thats the reason. Its normal.
Don't - it may cause errors while recording. This setting will be removed in the next DVBViewer release.
So it's normal. Thanks :D
You guys are a lot PROFESSIONAL :)
With standard settings the card and the softdecoder is not much slower than a standalone receiver with hardware decoder. But if you compare it with analog transmission, there's always a time delay for mpeg encoding/decoding and in case of satellite transmission vs. terrestrical transmission a round trip delay for the signal, which must go up and down. That can add up to a couple of seconds.
