Rec.Serv. and dua lSatelite tuner card
mborkP
I've Sat. Card which has 2 S-2 tuners on board. In DVBViewer settings, both tuners are listed as A and B Is there a way that the Unicast Network Device will see just one tuner? I.E. Is it possible to set up 2 Unicast Devices and assign each to different tuner?
Thanks
Thanks.
I did setup rec.srv. but still have a problem as with pre 4.5 betas. Problem is that when I record HD channel and while recording change to another HD channel I got "hardware not availible" message. If, while recording HD, I change to SD channel there there is no problems. If I run DVBV without rec.srv. I can record and watch HD or SD channels at the same time with no problems. This is for instant recording.
Also I noticed that the v4.5 is very sensitive to codecs, with some it start to pixelate, audio is out of sync ect. I did not have this behaviour prior to v.4.5.
It crashes all the time with ATI codecs. Maybe this is ATI drivers problem, not sure.
Cheers
Edited by mborkP
