culver Posted February 10, 2011 Posted February 10, 2011 hallo hoto 44, kannst du mir sagen wie man die Tastentöne in deinem Skin Fuison-X abschalten kann, die sind mir zu laut und zweitens brauche ich Sie nicht. Für deine Hilfe wäre ich dir sehr dankbar. mfg culver Quote
Tjod Posted February 10, 2011 Posted February 10, 2011 Lösch den Ordner Sounds im Skin Verzeichnis. Quote
culver Posted February 11, 2011 Posted February 11, 2011 Hallo Tjod, danke für den Tip, habe die Ordner gelöscht, jetzt hat dieses gepiepse aufgehört, Danke. mfg Culver Quote
ramonchin Posted October 9, 2011 Posted October 9, 2011 Hello, I did some fine-tuning and rework to my skin. The result I call "X-Mod Confluence" skin. Since I did many changes you should make a new install of this skin. Plugins and scripts are still the same as described and provided in my posts above. So please take and install them from there as described. Please unzip HomeImages.zip and copy them back in the images folder. For the home screens I am using the font "DejaVu Sans". If this should not be on your system either get it from somewhere or change it to another one in the corresponding .xml-files (home, myhome). Thanks. hoto44 Hi! Are you gonna release an online.dll file for this great skin? You know, the new function for watchin youtube on DVBViewer 4.9 Thanks Quote
hoto44 Posted August 14, 2012 Author Posted August 14, 2012 Skin update posted on 14th August 2012. Please see first post. KInd regards hoto44 Quote
trudeh Posted August 15, 2012 Posted August 15, 2012 @mx3000 Please note: skin contains now MR.SkinHelper functionality (BluFuzz - thanks to SnoopyDog). So you need the MR.SkinHelper plugin to be installed: http://www.DVBViewer...d-skin-blufuzz/ Try to install this plugin Quote
razer2007 Posted September 7, 2012 Posted September 7, 2012 Funktioniert in diesem Skin myepgsearch nicht? Bekomme nicht angezeigt. Quote
hoto44 Posted September 8, 2012 Author Posted September 8, 2012 Hallo, hier ist die neueste Version meines X-Mod-Confluence OSD-Skins (8. September 2012). Viele Design Fixes und Änderungen. Bug-Fixes im EPG Bereich. New version available in first post. hoto44 Quote
hoto44 Posted May 1, 2013 Author Posted May 1, 2013 Hallo,habe heute eine komplett überarbeitete Version des Confluence-X OSD-Skins (01.May 2013, 20.00Uhr) im ersten Post veröffentlicht. hoto44 Quote
nordstern70 Posted May 2, 2013 Posted May 2, 2013 Hallo, danke für diesen tollen Skinn. Kann mir vieleicht jemand sagen wie man Backdrop Dateien anlegt damit ich die Cover aufgenommener Filme im Media Center Menü im Hintergrund darstellen kann? Wie muss der Ordner dafür aussehen und wo muss ich die Daten hinpacken? Quote
