dotdkay Posted November 19, 2010 Posted November 19, 2010 (edited) Hey, I was wondering if it's possible to have DVBViewer start up with no video and sound maybe with some commandline input or other setting? It may seem strange that I dont need video/sound but im using DVBViewer for teletext over an remote desktop connection, and I would prefer to limit amount of data over the remote desktop connection. I know there's an option inside DVBViewer to disable video and audio, but that option is only available when I have started DVBViewer. Can somebody help me with this? Edited November 19, 2010 by dotdkay Quote
Tjod Posted November 19, 2010 Posted November 19, 2010 DVBViewer.exe –x16386 -x35 You can use the action IDs from the actions.ini (DVBViewer folder) with the -x parameter. Or take a look at the Web Interface 1.5 (Members Section) instate of using the remote desktop. It has teletext support as well. Maybe you need the Teletext Fonts (Members Section) on the client. Quote
lorenzo Posted December 19, 2010 Posted December 19, 2010 Actually, is it possible to have DVBViewer 'active' only when recording ? I'd like to have DVBViewer running continuously, but only accessing/using the dvb cards when recording a show. It seems to me the current behaviour after a recording is to stay on this channel and decode it, or at least the dvb usb card is still active since it stays warm. I schedule my recordings with the web interface, creating timers, and tick the disable audio/video checkbox. If that's not possible, is it possible to start DVBViewer Pro automatically with the timers ? In that case I could set the 'Quit DVBViewer' post-recording action (and hopefully, if there are multiple recordings at the same time, DVBViewer will stay alive). Your help is much appreciated, regards, Laurent PS: This is with DVBViewer Pro 4.2, I did not yet upgrade to 4.5. Quote
majstang Posted December 19, 2010 Posted December 19, 2010 (edited) Actually, is it possible to have DVBViewer 'active' only when recording ? I'd like to have DVBViewer running continuously, but only accessing/using the dvb cards when recording a show. It seems to me the current behaviour after a recording is to stay on this channel and decode it, or at least the dvb usb card is still active since it stays warm. I schedule my recordings with the web interface, creating timers, and tick the disable audio/video checkbox. Man, you're asking for a lot! This would require two persistant scripts constantly monitoring and querying the DVBViewer COM and the RS WEB API for changing values. Too much of a hassle to accomplish, unless you dont wanna write it yourself. The Scripting Lounge is a good place to visit then. http://www.DVBViewer.tv/forum/forum/40-scripting-lounge-com-deen/ If that's not possible, is it possible to start DVBViewer Pro automatically with the timers ? In that case I could set the 'Quit DVBViewer' post-recording action (and hopefully, if there are multiple recordings at the same time, DVBViewer will stay alive). Well, that is not possible, cuz the recording timers in RS do not have any PRE-RECORDING TASK option, making it possible to launch DVBViewer automatically before recording begins. The 'Quit DVBViewer' post-recording action however is possible if you use a script as a task closing DVBViewer. Use it as an after recording task instead of a post-recording action. Edited December 19, 2010 by majstang Quote
