about USB IR recievers
rapper
Hi
I have bought a IR (infra red) reciever and I wanna use it for controlling DVBViewer. As I have read in different forums it seems that USB versions don't work correctly for remote controlling
I am currently using it with my cell phone
Can anyone explain me? Is it possible to configure it with Girder or other programs??
Is it an IrDA Receiver?? Than it is very difficult, because that one is not suitable for the Remote.
I think so ;)
Does it mean that it's impossible to get it with a remote??
As far as I know in irda-receivers the receiving-logic is build in. and it is different from that of ir-remotecontrols. thats why it is difficult. maybe out there is a solution, but I don't know of such a thing.
Well. It doesn't look THAT difficult. If you put the ic on a socket it should be possible to complete such a task.
German translation:
Naja. So kompliziert siehts doch garnicht aus. Wenn man den IC sockelt, sollte das imho machbar sein...
Edited by Technofriend
