Kiwi_Tim Posted November 25, 2010 Share Posted November 25, 2010 Hi there, I'm considering purchasing a TBS-8921 DVB-S2 PCI card that supports DiSEqC 2.0 and can perform a true blind scan, without the user needing to input frequency range and SR. See here: http://www.tbsdtv.com/english/product/8921.html I'm wondering if anybody already has this working with DVBViewer and whether it performs well? I've always been envious of the set-top-boxes that can perform a fast automatic blind scan, like the Hyundai HSS760A, but I don't want to give up my DVBViewer enabled PC. It would be good if I could have both! Tim New Zealand Quote Link to comment
Derrick Posted November 25, 2010 Share Posted November 25, 2010 Blind scan is not supported by the DVBViewer. Quote Link to comment
ElecardFAN Posted November 25, 2010 Share Posted November 25, 2010 Well depends on, either select in depth scan (which includes parsing and using the NIT) or do not use a transponder list - which will force the DVBViewer to try all possible combinations. Quote Link to comment
Derrick Posted November 25, 2010 Share Posted November 25, 2010 ..which will force the DVBViewer to try all possible combinations. ..and who tells you which combination is the right one? The topic is "true blind scan" Quote Link to comment
Kiwi_Tim Posted November 27, 2010 Author Share Posted November 27, 2010 Well depends on, either select in depth scan (which includes parsing and using the NIT) or do not use a transponder list - which will force the DVBViewer to try all possible combinations. I guess this would take all day or possibly several days. I'd like to replicate a true blind scan that completes in a few minutes. This is interesting: http://www.proftuners.com/blindscan.html Tim New Zealand Quote Link to comment
Derrick Posted November 27, 2010 Share Posted November 27, 2010 ..yes, interesting indeed, but there you can also see that it's not supported by the DVBViewer. If the developers can get hold on the necessary api, it would nicely fit into transedit Quote Link to comment
CiNcH Posted November 27, 2010 Share Posted November 27, 2010 According to the linked page, a blind scan tool is provided which can create transponder ini files. So it does not necessarily have to be integrated into the DVBViewer. Quote Link to comment
