el_domingo Posted December 2, 2010 Posted December 2, 2010 I am using Terratec Cinergy Pci S2 and DVB-C both in my HTPC. When trying Transedit scan DVB-C give message "could not initialize dvb device...". I am using custom Transponderlist. DVBViewer scan fine. Terratec Pci DVB-C driver version: Cinergy_C_PCI_Drv_Setup_1.01.02.501_XP_Vista_7 Here transedit.ini hardware section as follows; [Hardware] Name.0=Cinergy C PCI Digital Tuner ID.0=@device:pnp:\\?\pci#ven_1822&dev_4e35&subsys_1178153b&rev_01#4&35e69562&0&30a4#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}\{bcc1431a-b717-4f7d-b47b-11ef8363798c} TunerType.0=0 Groups.0=255 Status.0=1 DeviceNr.0=0 DeviceType.0=1 StopStreaming.0=0 AutoRetune.0=0 StandardInterface.0=0 Vendor.0=5 InternalNP.0=0 TuningSpace.0=Internal Name.1=Cinergy S2 PCI Digital Tuner ID.1=@device:pnp:\\?\pci#ven_1822&dev_4e35&subsys_1179153b&rev_01#4&35e69562&0&38a4#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}\{acec2d03-bdec-44c0-9a97-c577f6ee2602} TunerType.1=1 Groups.1=255 Status.1=1 DeviceNr.1=1 DeviceType.1=1 StopStreaming.1=0 AutoRetune.1=0 StandardInterface.1=0 DVB-S2.1=1 DiSEqCCount.1=1 Vendor.1=5 InternalNP.1=0 TuningSpace.1=Internal Here Transponder as follows; (I copied and changed my frenquencies) [sATTYPE] 1=4000 2=KABLO [DVB] 0=383 1=86000,,2667 2=93000,,1778 3=93000,,1778 4=100000,,2160 5=100000,,2160 6=108000,,6250 7=108000,,6250 8=108000,,6250 9=108000,,6250 10=108000,,6250 11=108000,,6250 12=108000,,6250 13=108000,,6250 14=108000,,6250 15=108000,,6250 16=108000,,6250 17=108000,,6250 18=108000,,6250 19=108000,,6250 20=108000,,6250 21=108000,,6250 22=108000,,6250 23=108000,,6250 24=115000,,1734 25=115000,,1734 26=115000,,1734 27=122000,4,5714 28=122000,4,5714 29=122000,4,5714 30=122000,4,5714 31=122000,4,5714 32=122000,4,5714 33=122000,4,5714 34=122000,4,5714 35=122000,4,5714 36=122000,4,5714 37=122000,4,5714 38=122000,4,5714 39=122000,4,5714 40=122000,4,5714 41=122000,4,5714 Quote
Griga Posted December 2, 2010 Posted December 2, 2010 Important information is missing. http://www.DVBViewer.tv/forum/index.php?showtopic=2210 Quote
el_domingo Posted December 4, 2010 Author Posted December 4, 2010 here is support.zip support.zip Quote
Griga Posted December 4, 2010 Posted December 4, 2010 When trying Transedit scan DVB-C give message "could not initialize dvb device...". It's a known problem under Windows 7 with TransEdit 3.6, caused by the Microsoft Network Provider Filter. Launch TransEdit with administrator rights and take care that the device is used somehow. After that it will work without administrator rights. Another possibility is to tick Settings -> Hardware -> Use internal Network Provider filter (which is recommendable if it works with your device), but it isn't a general solution, because the problem will re-appear if you untick the checkbox. Quote
