spAik Posted July 11, 2004 Posted July 11, 2004 I think it would be usefull to add a function to the record-menu that you can type in two places on your hdd, where to store the recorded files. ie.: HDD1:2 gb HDD2:4gb, and when there is no space left on the first, DVBViewer continues to record the program to the second place (here HDD2) ..i hope you get, what i have ment Its a feature ChrisTV (analog capture-software) ie has and i think it could be needed sometimes... Furthermore a Screenshot-Option would be very nice (if there isnt one jet (i have only the TEdition)) Quote
Griga Posted July 11, 2004 Posted July 11, 2004 Furthermore a Screenshot-Option would be very nice The full version doesn't provide it either, but some DirectShow filters do, e.g. FFDShow. Actually it is a DivX/MPEG4 decoder (IMHO the best), but it can be configured in a way that it it used by the DVBViewer (even the TE): 1) Download the latest alpha version from http://sourceforge.net/project/showfiles.p...?group_id=53761 2) Install it and select 'Raw Video' in the Codec section (there should be a FFDShow Setup in the start menu after having installed it) 3) Launch DVBViewer, see wether it still works (FFDShow doesn't work with all MPEG2 video decoders under all circumstances). 4) The FFDShow icon should show up in the tray. Double-click it to open the FFDShow property page, 5) Go to the 'Grab' section and do your screenshots (select BMP, the other formats probably won't work). Quote
spAik Posted July 12, 2004 Author Posted July 12, 2004 thx for the quick reply...have to test that Quote
Guest Oliver Posted July 12, 2004 Posted July 12, 2004 The correct download link would be http://athos.leffe.dnsalias.com/ . There you'll find the latest releases. Bye Quote
Griga Posted July 12, 2004 Posted July 12, 2004 (edited) The correct download link would be I do not recommend these newer versions. They additionally install FFDShow as a MPEG audio decoder with questionable results. If one is not familiar with the DirectShow settings, it may cause trouble... Edited July 12, 2004 by Griga Quote
