4.5 clashes with Antivirus and no file association
ddichiera
Installing 4.5 on Win7 x64, I get a trojan warning by my AVP (Kaspersky).
Assuming it doesn't actually contain a virus, I bypassed the AVP for installation.
Not everything went smoothly e.g. renderer issues but the main problem is that I can no longer make a file association to DVBV. When I try to open file with... I select DVBV, but it just closes the explorer window.
See here for AVP log:
14/11/2010 00:57:09 Task started Proactive Defense Kaspersky Internet Security
14/11/2010 00:57:26 Detected: PDM.Keylogger kernel mode memory patch Absent
14/11/2010 00:57:26 Detected: PDM.Keylogger kernel mode memory patch Action selected by user Absent
19/11/2010 02:08:35 Task started Proactive Defense Kaspersky Internet Security
20/11/2010 13:47:57 Task started Proactive Defense Kaspersky Internet Security
20/11/2010 13:48:10 Detected: PDM.Keylogger kernel mode memory patch Absent
20/11/2010 13:48:10 Detected: PDM.Keylogger kernel mode memory patch Action selected by user Absent
23/11/2010 00:39:24 Task started Proactive Defense Kaspersky Internet Security
23/11/2010 01:37:15 Task started Proactive Defense Kaspersky Internet Security
23/11/2010 01:41:50 Task started Proactive Defense Kaspersky Internet Security
23/11/2010 01:44:17 Task started Proactive Defense Kaspersky Internet Security
23/11/2010 01:49:23 Task started Proactive Defense Kaspersky Internet Security
23/11/2010 01:49:46 Detected: PDM.Keylogger kernel mode memory patch Absent
23/11/2010 01:49:46 Detected: PDM.Keylogger kernel mode memory patch Action selected by user Absent
23/11/2010 23:01:47 Task started Proactive Defense Kaspersky Internet Security
24/11/2010 16:38:12 Task started Proactive Defense Kaspersky Internet Security
29/11/2010 16:55:47 Task started Proactive Defense Kaspersky Internet Security
30/11/2010 19:27:16 Task started Proactive Defense Kaspersky Internet Security
03/12/2010 21:19:03 Task started Proactive Defense Kaspersky Internet Security
09/12/2010 18:46:37 Task started Proactive Defense Kaspersky Internet Security
10/12/2010 01:33:09 Task started Proactive Defense Kaspersky Internet Security
11/12/2010 15:29:18 Detected: PDM.Worm.P2P.generic G:\DVBViewer\DVBViewer 4.5\SETUP.EXE DVBViewer Pro Setup
11/12/2010 15:29:18 Detected: PDM.Worm.P2P.generic G:\DVBViewer\DVBViewer 4.5\SETUP.EXE Action selected by user DVBViewer Pro Setup
11/12/2010 15:29:18 Terminated: PDM.Worm.P2P.generic G:\DVBViewer\DVBViewer 4.5\SETUP.EXE Action selected by user DVBViewer Pro Setup
11/12/2010 15:29:20 Deleted: PDM.Worm.P2P.generic G:\DVBViewer\DVBViewer 4.5\SETUP.EXE Action selected by user DVBViewer Pro Setup
Dominic
oh BTW, I can't get supporttool to work. I get the following error message:
"This program must be started in the DVBViewer folder!"
I put it in the config folder, is that correct?
Dominic
Thanks for clarifying this matter.
I hadn't seen the post regarding false alarms even though I had done numerous searches.
Dominic
  • 1 year later...
Saw the same here.
If you have a digital signature, you might want to consider signing the setup EXE's as it would prevent KAV from complaining.... (as it defaults to not proactive scanning digitally signed files).
Well a digital signature does cost a lot of money (on yearly basis) which has to come from somewhere. 15€ - 19% VAT and no follow fees for updates doesn't leave much...
