PeterF Posted December 31, 2010 Posted December 31, 2010 Ich versuche gerade mal alle Bezeichnungen dieser Karte(Azurewave AD-SP400) zusammenzutragen um sie dann eventuell wenn erwünscht im Wiki bei der Hardware mit anzuhängen. Das habe ich schon: Azurewave/Twinhan AD-SP400(1041) MSI MSI TV@nywhere Satellite II Technisat SkyStar HD 2 TerraTec Cinergy S2 PCI HD Twinhan DVB-S2 PCI Sat CI Ich habe leider hier im Forum und auch anderswo feststellen müssen das viele Leute nicht wissen, dass es sich um die selbe Hardware handelt und bei Problemen von einem Clone zum anderen wechseln und sich dann wundern das die Problem nicht weg sind. PeterF Quote
fxv1 Posted June 22, 2011 Posted June 22, 2011 (edited) I use a Twinhan DVB-S2 PCI Sat CI , sadly I cannot read german. Are you asking something ? Frank Edited June 22, 2011 by fxv1 Quote
PeterF Posted June 22, 2011 Author Posted June 22, 2011 I only was collecting the names and manufacturers of this card, because there are many of this and it is easyer to give support if anybody is asking. Then anybody can say, look at this card, it is similar to the Azurewave and has the same problems. I had written the correct names in the Hardware-Database in the german Wiki. btw, thank you for your answer. PeterF Quote
fxv1 Posted June 22, 2011 Posted June 22, 2011 I only was collecting the names and manufacturers of this card, because there are many of this and it is easyer to give support if anybody is asking. Then anybody can say, look at this card, it is similar to the Azurewave and has the same problems. I had written the correct names in the Hardware-Database in the german Wiki. btw, thank you for your answer. PeterF Hi Peter, if you need any info for that device let me know. I am having some problems with DVB-S2 since the change over in the uk on 6th June. http://www.DVBViewer.tv/forum/topic/46077-dvb-s-v-dvb-s2/page__view__findpost__p__339522__fromsearch__1 Thanks Frank Quote
