shpiritus Posted July 19, 2004 Posted July 19, 2004 i have used sky 2 pc for 4 years on some aopen MB, and now i get some new asus A7N8X-X MB.The card work but is to hot.Is not in first slot under agp. Can you help me? Quote
Gioxy Posted July 19, 2004 Posted July 19, 2004 Hi shpiritus, normally you can add an addictional fan to the case... I suggest to add one on the rear of the front panel that push the air inside, so to create a forced air flow that refresh the PCI slot area... Alternatively, if you love DIY , you can add an aluminium heat dissipator to the SS2 chip (you have to use an adhesive thermoconductive pad or paste to fix it), or a little fun like those used for 486 cpu (...and find your own a way to fix it to the board...) Cheers Gioxy Quote
