Channel scan, only HD channels
Tom Wideroe
Try with TransEdit (available for dwnl in Member Area)
:bye:
I|m trying the TransEdit tool, but it says "Initialising the DVB deveice has failed. Performing a new hardware detection on Settings -> Hardware may help."
Well, it does not...
This is bloody frustrating...
Link to comment
Initialising the DVB deveice has failed... Performing a new hardware detection...may help... it does not...
Most probably some other prog are using the card (Terratec one?)... and: have you installed Transedit in DVBViewer's main folder?
:bye:
Link to comment
Launch TransEdit once with administrator rights and make sure that TransEdit uses the device (e.g. by scanning). After that it should work without administrator rights.
or
Settings -> Hardware -> Tick "Use internal Network Provider filter". However, this is not a general solution.
Link to comment
