TVSeer Posted January 31, 2011 Posted January 31, 2011 Hi DVBViewer forum. I just installed DVBViewer PRO V. 4.6.0.1 yesterday, and also installed DVB Task Scheduler 2.2.3.12. To be able to watch HD TV I installed DivX Plus codecs. The problem is this: When I watch a TV channel in DVBViewer, and press the red RECORD button on the toolbar I can record a .ts file, and while recording i can open RECORDER CONTROLS, and verify, that there are 0 stream errors. The .ts file thus plays fine in DVBViewer. When I schelduele a timer recording using DVB Task Scheduler 2.2.3.12, and sets the computer to hibernate, it wakes up from hibernation in time, and starts recording. But if I - while recording - open RECORDER CONTROLS, I can se a huge number of stream errors. For example I recorded a 1,91 GB .ts file, and it had more than 138000 stream errors. Thus if I try to play back the recorded file in DVBViewer I get an error no. 0x80040217, and the file can not be played. Why do I get stream errors in a scheduled recoding, but not in an instant recording? Can anybody help me? The support.zip file is attached. By the way: In support.zip it says, that my graphics adapter is ATI Radeon HD 2400 PRO. That is wrong. My graphics adapter is ASUS Nvidia GeForce GT 240. Regards TVSeer support.zip Quote
TVSeer Posted February 2, 2011 Author Posted February 2, 2011 I solved the problem to some extent. The stream errors ocurring when i recorded was only present when the PC woke up from STANDBY. If I left the PC turned on no erros would occur. In the PC´s BIOS in the menu POWER SETTINGS i changed the ACPI suspend mode from S3 to S1. Now I can scheduele working recordings when the PC wakes up from STANDBY, but sometimes I get 0,00 Kb recordings when the the PC wakes up from HIBERNATION. I guess I will have to use STANDBY, and not HIBERNATION, allthough I would like to save more power. Maybe someone in this forum can give a hint. Regards TVSEER Quote
