Reading Fileinfo in Windows 7
Cian
I have just converted my HTPC from XP to windows 7. In both XP and 7, I had the "Save EPG as fileinfo" option selected. I used this information to log series and episode numbers, particularly for radio recordings. Now that I am in Windows 7, I can't find this information anywhere in the properties page of the recording. This seems to be the case with recordings made both before and after the changeover.
Where can I find this info?
I also had the advantage in XP that when I hovered over the file, the summary was displayed. Now I just seem to get the date and file size. It would be nice if the fileinfo could be displayed in the summary at the bottom of the widow where the thumbnail is displayed.
I looked through the properties tab, which resembles the Advanced fileinfo in XP. I have also tried to change the folder settings to display it, but I don't know if it is still there to display.
Anyone any ideas?
Thanks,
Cian.
Excellent - Thankyou.
Cian.
Edit: Doh! 32 bit only.
Edited by Cian
