BigZ12 Posted February 10, 2011 Share Posted February 10, 2011 Hi there! I have a Terratec H7 DVB-C external TV-card. I am connected with Canal Digital Cable in Oslo, Norway. Norwegian Broadcasting Company (NRK) have just released 3 new HD channels . They are located at 134.000Mhz - Symbolrate 6950 - QAM256. I don't find any way to manually change to these settings. There's not any frequency at 134.000, just 128.500 and then the next intervall is 135.500. It's not possible to force the freq. to 134' BTW: I can tune into the channels using Terratec Home Cinema, just manually set the freq. to 134.000. (But THC is useless in my system, a lot of stuttering, and I have to use DVDViewer for the best picture.) Hope you understand my problem. Can you help me? Quote Link to comment
PeterF Posted February 10, 2011 Share Posted February 10, 2011 Download from the Members-area the tool "Transedit", install it like written in the documentation and with this tool you can scan all frequencies and parameters you want and at finish you can export the results into DVBViewer pro. PeterF Quote Link to comment
BigZ12 Posted February 10, 2011 Author Share Posted February 10, 2011 Download from the Members-area the tool "Transedit", install it like written in the documentation and with this tool you can scan all frequencies and parameters you want and at finish you can export the results into DVBViewer pro. PeterF Fantastic! Thanks for your quick answer. I will try now. Hope I get it to work. BigZ Quote Link to comment
BigZ12 Posted February 10, 2011 Author Share Posted February 10, 2011 (edited) I found the channels with Transedit. They were as I said at 134Mhz - symbolrate 6950 - QAM256. But when I try to export, I get this message: "Sorry - cannot export since DVBViewer 2.1 (or later) is not present" Why? I have DVBViewer 4.6. I am using Win7 Ultimate x64 english version. Edited February 10, 2011 by BigZ12 Quote Link to comment
PeterF Posted February 10, 2011 Share Posted February 10, 2011 You must install Transedit like written in the docu in the folder where DVBV is, no subfolder, only copy from the zip-file into the DVBV-Folder. PeterF Quote Link to comment
Tjod Posted February 10, 2011 Share Posted February 10, 2011 http://www.DVBViewer.com/griga/TransEdit%20E/General.html#Installation Quote Link to comment
BigZ12 Posted February 10, 2011 Author Share Posted February 10, 2011 Thanks guys! Worked like a charm! Now I'm ready for the Nordic World Ski Championships 2011 in Holmenkollen, Oslo on HD channels with 5.1 sound. Thanks again! Quote Link to comment
