no radio in current beta
pastimer
In the current beta, tried this with a number of upnp clients, there is a problem with the recording service's upnp server regarding radio. Dvbserver unicast does work however (where i use DVBViewer as a client).
Could someone verify this?
The error message says invalid file format.
In earlier versions i was (sometimes) able to listen to sat radio.
Eppo.
Ffmpeg! Thanks.
ffmpeg??
Not ffmpeg. Would also be unlogical as NMT's eat mp2, mot wav.
I was looking at the wrong server. No, the current beta just wont stream radio (mp2) to popcornhour at my home.
I still had a 1.5... version somewhere so i installed that and all is well again now on this system.
So as far as i can see it IS a problem in the current beta.
Regards, Eppo
Support.zip attached.
I would appreciate some help.
Epposupport.zip
..doesn't work here either. Maybe it's broken?
Correction: after a couple minutes of buffering time I get a sound from my popi. You'd better forget to listen to the media_server_radio on your popi :blink:
..btw stream info on my A110 shows mp3 as stream type but I have ffmpeg in the installation folder ;)
Working here too know. I had installed ffmpeg, but just the codecs, not the exe in program files/DVBViewer...
The long delay is a popcornhour problem. It seems the NMT fills up a portion (around 70%) of it's buffer of 8MB before it starts playing. Therefore buffer times are a lot less when playing a HD video source... However, when mp3 is played from the network, buffering is not that long. So, still a bit mysterious.
Btw i'm not going to drop sat-radio ....It's too damn good. :rolleyes:
Edited by pastimer
