TBS6981 Diseqc switching problem
brutus
I use DVBViewer 4.6.0.1 icw recording service 1.6.9 Beta.
I have TBS6981 dvb card, driver 2.0.0.14.
Running Win7.
I have diseqc 1.0 with 2 LNB's: 0 = astra 23.5, 1 = 19.2
While scanning I can find all channels, for both LNB's.
When I want to watch the channels I have switching problems between LNB 0 and LNB 1.
(I have the same issues with WinXP, even on older versions of DVBViewer/Rec service, and similar issues with another dvb card/technisat HD)
When using transedit I can see that I've the wrong channels for the LNB (which means the diseqc did not switch).
What I find strange is that scanning works, it finds the correct channels for the LNB's, while transedit and channel switching doesn't work.
I also experimented with Linux (yavdr) and there I don't have any channel switching issues.
Used diseqc.conf in linux:
S23.5E 11700 V 9750 t v W15 [E0 10 38 F0] W15 A W15 t
S23.5E 99999 V 10600 t v W15 [E0 10 38 F1] W15 A W15 T
S23.5E 11700 H 9750 t V W15 [E0 10 38 F2] W15 A W15 t
S23.5E 99999 H 10600 t V W15 [E0 10 38 F3] W15 A W15 T
S19.2E 11700 V 9750 t v W15 [E0 10 38 F4] W15 B W15 t
S19.2E 99999 V 10600 t v W15 [E0 10 38 F5] W15 B W15 T
S19.2E 11700 H 9750 t V W15 [E0 10 38 F6] W15 B W15 t
S19.2E 99999 H 10600 t V W15 [E0 10 38 F7] W15 B W15 T
How can I further debug what is wrong and why the diseqc is not switching ?
Please describe more in detail what you try with which DiSEqC settings.
In transedit I select for astra 23.5 = PosA/OptA (LNB 0), and for astra 19.2 = PosA/OptB (LNB 1). Then I select a transponder from astra 23.5 and do an analyze, I get incorrect channels, I get the channels from the astra 19.2. When I select a transponder from astra 19.2, I will get the correct channels from the transponder.
I've noticed that I could get it to work when first selecting an astra 19.2 transponder and quickly after it selecting an astra23.5 transponder I get the correct channels. When analyze again the astra23.5 transponder often fails. It works again after going back to astra19.2 and then to astra23.5.
I have problems of selecting channels from astra23.5 (first LNB), channels from astra19.2 (second LNB) is not a problem.
I've played with the extended diseqc settings, various combinations (incl delays), no result.
I don't want to do anything special with the diseqc.conf settings (from previous post), I wanted to show you that with these settings in vdr I could switch to lnb 0 and lnb1 and vice versa.
..hmm, why do you select A/B? In transedit it is shown as the 3rd position. B/A makes more sense to me and will correspond to your diseqc.conf settings ;)
sorry mistake, astra 23.5 = PosA/OptA (LNB 0), and for astra 19.2 = PosB/OptA (LNB 1)
  • 1 month later...
It seems other people have the same issues with diseqc.
refer
http://www.DVBViewer.tv/forum/topic/45245-diseqc-10-mit-einer-tt-cinergy-s2-hd-pci/
http://www.DVBViewer.tv/forum/topic/44939-proble-switching-polarity-hauppauge-dvb-s2-card/page__p__331054__hl__diseqc__fromsearch__1#entry331054
My setup:
diseqc 2.0
Lnb0: duo : astra 23.5
Lnb1: quad: astra 19.2
I could have electrical problems since my cable is 40m.
But since I don't have channel switching issues on Linux .... Are they doing something 'special/different' which solves diseqc-switching issues?
When analyzing with transedit I see following strange issues:
If I analyze a transponder on astra23.5 (freq = 12129), I get wrong channels, it looks like they are form astra19.2, when switching to astra19.2 transponder (freq = 10744) and then switch back to astra23.5 (12129) I get correct channels. Closing the analyze screen and analyze again gives me again wrong channels, the channels from astra19.2 !
Sometimes I notice that also switching to astra 19.2 transponder gives no channels during analyze.
I tried with retune after x sec, stop streaming while tuning, using extended diseqc (sending twice diseqc command, with/without delay) ...
I'm desperate !
What else can I do ?
