Please change in next Czech language file
peter21
Please can you change in czech language file Shutdown Warning ?
(to be more apposite which action is timed)
now:
Shutdown action by timer=Načasovaná akce
better translation:
Shutdown action by timer=Načasované vypnutí počítače
Thank you in advance. Petr
Please attach corrected language files here, if you want changes to be adopted. Thank you in advance...
  • 2 months later...
I just updated the Czech language file - new version is attached in this post. :rolleyes:
  • 7 months later...
now:
better translation:
I found out that the same text "Shutdown action by timer" is shown also when different action is timed, not only with real Shutdown. So I decided to keep some "more universal" translation here.
Latest language file is available for download in this thread.
  • 2 months later...
I would first like to thank the people what DVBViewer translated into Czech. I understand that the translation is difficult. I found when using DVBViewer, four errors. I fixed it. The modified language file attached.
Errors:
fmMain line 113 actUPnPOpen.Caption Open UPnP ... (Otevřít UPnP ...)
line 136 MnuOpen.Caption Open (Otevřít)
OSD line 202 Clear Clear (Jasno)
Unfortunately, I not found an item in the forecast called Sprinkles. Edit I tested and it worked. Yet I hope that my modifications are in order.
Czech language file.zip
Edited by George06
  • 1 month later...
I have taken note of your suggestions, thank you. Updated Czech language file is here:
New and complete Czech translation
