Encrypted channels with Anysse E7-S2
hello,
I bought the license for DVBViewer pro but I can not watch encrypted channels on my subscription CanalSat (France). I have a tuner Anysee E7-S2 with a CAM AstonCrytpt V2.
I can see the unencrypted channels but not the chains of my subscription.
With the tool of the site, I see the tuner Anysee E7-S2 is compatible with DVBViewer but underneath it says "Anysee analog capture" not compatible.
Can anyone help me?
with that, the CAM information is not available.
The CI module option is checked.
Compatibility problem with the CAM ?
The team will work on this problem ?
thx
AFAIK DVBViewer Pro does not provide CI support for Anysee devices. Sorry, no better news...
ok thank you :(
you think it will be repaired in a future update?
  • 4 weeks later...
Hello,
what news with the support of Anysse E7-S2 ?
i have the same probleme with my powercam pro dvbwiewer do not detect the cam
OH ! really ? great new ! thx (w00t)
I'm in a hurry to use my tuner with DVBViewer.
hello ! whohooo big thx for the update ! ;)
but ... i have always the same problem with this new version 4.8.0.1 :huh:
impossible to watch encrypted channels (and the CI module option is checked).
I have a SmartWi, this is not the problem ?
thanks for the help.
EDIT : it's ok, we must close the program Anysse in the system tray :blush:
now I'm going to use DVBViewer, great job i like this program !
Edited by yogy
That's correct. Anysee is aware of the problem.
I did the upgrade, I uninstall Anysee and DVBViewer program, and I did a fresh install of DVBViewer
........... all work normally .....
thank you (w00t)
There will be a driver update next week that will fix the CNO tool conflict issue.
I have a problem with getting pay channels to work on my AnySee E7 T2 in DVBViewer V4.8.0.1 (Sweden).
- I have the appropriate CAM and pay card from my provider: Boxer CAM CI+ DVB T2 (They don't use pairing yet).
- I have closed the Anysee CNO program from the traybar.
- I'm using the latest Anysee drivers 1.6.17.34 (2011-04-21)
All free air channels work perfectly, including HD T2 channels. When I switch to a pay channel SD or HD I only get a black screen in DVBViewer. No error message. No nothing. When I check the AnySee traybar app. I can see that my pay card is inserted correctly and that it can be read. Also when I use the pay card directly in my TV it works fine.
What could be the problem?
Edited by qstoffe
No I don't have the "ciapi.dll" in the DVBViewer folder? Where would I get that from?
Also I have attached the support.zip file.
you can download it at the end of the installation or via the DVBViewer program group -> DVBViewer downloader.
Thanks! It works perfectly after I did this.
Edited by qstoffe
  • 3 months later...
Hi, I have the same problem that I can not open the encrypted channels but even with the ciapi.dll in the DVBViewer it does not work!
This is a brandnew Toshiba laptop with windows 7/64 and I do not have this problem using a Netbook with windows 7/32!
What could be the reason?
Using TV-Vlaanderen.
Bill
