hoto44 Posted July 12, 2012 Author Posted July 12, 2012 (edited) ..this must be an issue with your system. I can download all files without any issues. I can only imagine one issue which is related to the micro media script / plugin: http://www.DVBViewer.tv/forum/topic/40526-micro-media-info/ hoto44 Edited July 12, 2012 by hoto44 Quote
hoto44 Posted August 5, 2012 Author Posted August 5, 2012 OSD skin version Evolution-X-Frames II updated on 4th August 2012. Contains now a light blue background. Kind regards hoto44 Quote
hoto44 Posted August 8, 2012 Author Posted August 8, 2012 ...please use the attached myminiepg.xml file and replace it in the skin folder if SNR progress bar is not showing up. myMiniEPG.xml Quote
hoto44 Posted December 22, 2012 Author Posted December 22, 2012 (edited) Hi, OSD skin Evolution-X-II updated on 22nd December 2012 . This is a major rework of the skin. Please see first post for skin files. Hava a nice Xmas hoto44 Edited December 22, 2012 by hoto44 Quote
scotch Posted January 31, 2013 Posted January 31, 2013 (edited) Hallo, wirklich ein Super Skin. Zwei Kleinigkeiten würde ich mir wünschen: Im Aufnahmen Fenster die Positionen des Blauen Menu und Gelben Löschen Buttons tauschen, da die Reihenfolge dann der Reihenfolge auf den meisten Fernbedienungen gleicht. Wenn zusätzlich zur Anzahl der Objekte auch noch der verfügbare Festplattenplatz angezeigt würde wäre das optimal. Gruß scoTch Edited January 31, 2013 by scotch Quote
