No sound with AC3Filter
Jraf
Hello,
got new HD channels on french DVB-T
no sound so AC3 Filter 1.63b installed
audio options with AC3Filter enabled
still no sound at all with :
- TF1 HD (AC3, qaa) audio mode AC3
- France2HQ (qaa) audio mode AC3
- M6HD (qaa) audio mode AC3
- M6HD (qad) audio mode AC3
ACFilter says :
Input format: AC3 - 48000
User format: PCM16 2/0 (stereo) 0
Output format: Unknown - 0
Decoding chain:
(AC3 - 48000) -> Decoder -> (Unknown)
Filters info (in order of processing):
Decoder:
Out of sync
any solution ?
Thanks
Edited by Jraf
Most likely it's not AC3, but EAC3 (Enhanced AC3, Dolby Digital Plus, a modern AC3 variant). The AC3 filter is not able to decode it. You'll need the ffdshow audio decoder.
Woau !
I didn't even had time to edit my post to add the supporttool I forgot
and a solution came !
I installed ffdshow_beta7, and it works
well done
Thank you very much
