vthumbs.exe crashing on Windows/ 64bit
barrygreybeard
In my Windows logs I see the following entires:
Faulting application name: vthumbs.exe, version: 1.2.4.0, time stamp: 0x2a425e19
Faulting module name: ad2h264dec.004, version: 1.4.0.21597, time stamp: 0x4731f456
Exception code: 0xc0000005
Windows 7 SP1 64bit
DVBViewer Pro V4.6.0.1
DVBViewer Recording Service V1.6.9.0
This is a new install, any ideas why it crashes?
thanks
Barry
Works fine here, with same Windows / DVBViewer / Recording Service versions. Did you start the vthumbs.exe once directly from explorer (better by right click - run as administrator) to configure the codecs for SD and HD? I set it to the same codecs and settings I use in DVBViewer and have no Problems.
I have never run or used the program manually, I assumed it was called by the DVBViewer program itself.
Barry
OK I see what you mean, it was trying to use a codec that it obviously couldn't. thanks
Edited by barrygreybeard
