majstang Posted March 18, 2011 Posted March 18, 2011 On tab TV Guide (weekday buttons) and tab Status (EPG Records) there is still some unicode trouble. Nordic letters wont display right, no problem in EPG and everywhere else in the webinterface though. TV Guide: Status:
Lars_MQ Posted March 18, 2011 Posted March 18, 2011 Thanks, there will be more places where the Short day names are not encoded correctly. I fixed it. BTW the thousandseperator on the statuspage, how should it look like?
majstang Posted March 18, 2011 Author Posted March 18, 2011 BTW the thousandseperator on the statuspage, how should it look like? Sorry, I cant say cuz I cant go back to a non-unicode version now when all config files are already utf-8 encoded. It would require a total uninstall and deletion of all config files and im not willing to do that at the moment. Maybe someone reading this hasnt upgraded to RS 1.7 yet can answer Lars question? My guess would be a punctuation symbol. Cant be a "comma" cuz that is displayed right in the Data send box.
Lars_MQ Posted March 18, 2011 Posted March 18, 2011 You could switch to char coding in the IE back to Western (Windows) to see which char it is. After that just switch back to UTF8.
Lars_MQ Posted March 18, 2011 Posted March 18, 2011 Newline? I think something is off with your locales settings... A newline should not be there. A "." or a "," would be normal. Anyway, I convert this from ansi to utf8 now, just in case such strange settings are used
majstang Posted March 18, 2011 Author Posted March 18, 2011 (edited) Newline? I think something is off with your locales settings... A newline should not be there. A "." or a "," would be normal. Anyway, I convert this from ansi to utf8 now, just in case such strange settings are used Thanks Lars! I do use Windows 7 default swedish locales settings. Never touched them. Edited March 18, 2011 by majstang
majstang Posted March 18, 2011 Author Posted March 18, 2011 Yes, im sure it will. I do think we have some language confusion here...the character im refering to is called "blanksteg" in swedish and I think it is called "space" in english.
HaraldL Posted March 18, 2011 Posted March 18, 2011 I just tried to select swedish locale: The thousands separator is a "protected space" (hex $A0), not a usual space (hex $20) but visually identical. This is intended to avoid word wrap within a long number. With a protected space a number on the end of the line is moved completely to the new line if it doesn't fit and not broken in two parts.
uglyned Posted March 18, 2011 Posted March 18, 2011 Apostrophes stopped working here. Installed on Windows 7 32 but accessed from anywhere. This screenshot is from IE8 on an XP machine. I'm not at the PC the service is installed on so can't add a support.zip.
Lars_MQ Posted March 18, 2011 Posted March 18, 2011 Most likely this text is in the original EPG. This happens sometimes. Apostrophes are not UTF-8 related but html related encoded.I checked it here and it works and is displayed as it should.
uglyned Posted March 18, 2011 Posted March 18, 2011 All those apostrophes looked OK in previous recording service. I'm not saying recording service is wrong, but have you got any ideas how I would fix this on my PC so that it looks as it should? It's every single apostrophe in the EPG, so it's there quite a lot. Apostrophes work OK on this site - '''''''
majstang Posted March 18, 2011 Author Posted March 18, 2011 (edited) Most likely this text is in the original EPG. This happens sometimes. Apostrophes are not UTF-8 related but html related encoded.I checked it here and it works and is displayed as it should. Yes, but ' is XML unicode not its html eqvivalent. HTML doesn't officially support ' I found this that explains it better than i can. http://blogs.msdn.com/b/kirillosenkov/archive/2010/03/19/apos-is-in-xml-in-html-use-39.aspx Edited March 18, 2011 by majstang
Lars_MQ Posted March 18, 2011 Posted March 18, 2011 could you send me your epg.dat and channels.dat via PM? Then I'll check it.
Lars_MQ Posted March 18, 2011 Posted March 18, 2011 OK scratch that. I found the problem. The wrong encoding routine is called. Most browsers do handle it correctly, but not all it seems. I'll upload a hotfix later today.
temeteus82 Posted March 22, 2011 Posted March 22, 2011 (edited) Got similar issues with Finnish locale and I'm using IE9 RTM. Basically all the special letters for Nordic locales aren't displayed correctly. [EDIT] I got the 1.7.0.1 (beta) release date 18th of March.... [EDIT2] It only appears in Programs Overview. Edited March 22, 2011 by temeteus82
janip Posted March 22, 2011 Posted March 22, 2011 (edited) Only line end is wrong. http://japesone.kapsi.fi/kaverigallery/Images/kavija_kuvat/unicode.JPG Edited March 22, 2011 by janip
