Problem with scanning some HD channels
bfc_xxx
I am having troubles with scanning some hd channels.
eg NatGeo HD at sky italia:
while it should have been: 11785/H/29900 2/3 video pid:2514 service pid:14236
I have a tbs 6921 dvb card. What am I doing wrong?
Can anyone at least scan skyitalia at hotbird and upload the channellist so I can import the correct channels?
Thanks for the list :rolleyes:
Adjusting diseq options didnt help the scanning though.
Edited by bfc_xxx
this file from @Griga isn`t for scanning, it is for importing in your existing channellist and after this you must or must not adjust the DiSEqC and you have your channels from this frequencie in your list.
PeterF
PeterF
Yes I added the channels with that file, no problems with that.
I just tried to scan again after trying adjusting some diseq settings as Griga proposed.
Scanning with transedit solved my problem.
Thanx for the replies :)
