DVBrecorder service LiveTV
it's does work perfect but is there any option to decrease the buffer to move faster
and another problem (DOES it support -dvb- Subtitle )? cause did not work for me or this limitation of ffmpeg?
BR
cheers
Edited by AjeeB
what are you talking about exactly? Which client etc...
hi,
I talk about stream to iphone/ipad everything ok but no subtitle included (DVB subtitle) ... no problem with direct play with DVBViewer
btw I using latest dvbviewerRecording service
BR
any idea? can't find any info about it even in iphoneprefs.ini !
br
hi,
BR
ffmpeg does not support dvb subtitles and teletext subtitles to my knowledge.
Well, it is not clear what type of subtitles the document is referring to. Why not try the options the document descibes and see if it works? Else I suggest you to contact ffmpeg and query if the recommended ffmpeg version for Recording Service supports dvb and teletext subs. If so you could always request a subtitle feature added to the RS iphone streaming.
  • 3 weeks later...
hi,
BR
Can you work with the iphone outside the local network that it´s installed the server???
thanks
For me, i have subtitles for 80% of my channels with dvb rec service or dvblink+ mce( this one is another program that stream to iphone)
I higly doubt these subtitles are the DVB Subtitle or Teletext kind. More likely the hardcoded kind.
my subs are dvb and also hardcoded, no teletex included.
I have 2 subtitles type, one of it is when subs are included, no option to choose another one.
second type, i could choose from 4-5 subtitles type.
These 2 types is working ok on Iphone, but not all of them.
Hardcoded subtitles are working 100% all of them.
The rest only 80% or so
Edited by bogdan1980
have u test it with iDevice or ps3 cause no subtitles at all ! I don't talk about dvblink+ maybe it's different
if you read my previous post, yo ll notice i talk about iphone.
for iphone and ipad sub are working.( 80% of all).
you need to set for language sub in DVBViewer proggram.
Start DVBViewer- options-subtitles , and at DVB Subtitles, activate this: ENABLE IF AVAILABLE.
Also choose your language here.
You have here posibility to choose from 2 languages, example of mine, i'm romanian, we are latin nation, i choose romanian at LNG 1 and at LNG 2 i choose spanish, or italian, or french because romanian, spanish, italian, french and portughese are part of latin word, they are very close to each other.
And also enabled ATSC closed captations, AlwaYS CHECK FOR ATSC CAPTATIONS.
Also, with dvblink, same situation ,80% of my sub are working.
in dvblink you need to set language in server option.
?? but DVBViewer has nothing to do with streaming to iPhones/iPads :huh:
Can somebody else confirm if DVB Subtitles works when streaming to iPhone/iPad?
Teletext subtitles does not work at all.
@bogdan1980
Maybe you could share/upload a short .ts example? Just to see if DVB Subtitles works when being streamed to iPhone. Would be intresting to analyze this file.
Edited by majstang
