Teletext window does not show contents
zkab
When I open the teletext window it only shows the first headline ... check Page 100 (1).JPG
but when I copy it to clipboard it show the correct information ... check text.txt
What have I missed ?
text.txt
Are other teletext pages affected?
Seems to be a black characters on black background thing... maybe the broadcasters fault. If you provide a TS sample file containing teletext, I can have a closer look at it.
It seems to happen on every TV channel.
The .ts file shows teletext OK
How can I provide this .ts file ... it is 6 MB big ... got a warning that I am not permitted to upload this kind of file
When you play it? That's strange.
Some hoster like RapidShare or Megaupload...
Something you can try: Options -> EPG -> Teletext -> Restore Colors -> OK. Maybe something went wrong with your settings.
Yes - when I play the .ts file and activate EPG during play back the EPG is OK.
I have also tried Options -> EPG -> Teletext -> Restore Colors -> OK ... same sad result
FYI - I use EPG that is sent via TV signal.
I can't see anything particular with SVT1 teletext.
select another font in the teletext options (->Courier New).
It didn't make any difference in my case ...
Sorry, but I can't figure a reason for "teletext characters are present on file playback, but not on live TV". Teletext block graphic elements are rendered fine, as your screenshot shows, but not the characters. Some strange interaction with whatever seems to kill the DVBViewer's ability to display them in the teletext window. This issue has never been reported before... it's a mystery.
Try DVBViewer 4.8... maybe the issue goes away.
