RS and Streaming
Hey people,
I have some problems with my RS, actually I have had it since RS changed from using VLC 0.86 to the newest version.
I simple can't get it to stream via 3335 (or with transcoding enabled), it works perfect with direct connection.
My setup is
Pentium e5400
6GB ram
Zotac GF9300 mATX
Freshly installed Windows 7 sp 1 (danish language if that matters anything)
Turned off my firewall
2x Terratec cinergy c pci
1x Terratec h5
Newest VLC 1.1.9
RS 1.7.2
DVBViewer pro 4.8.0.0
I must be doing something wrong, but I simple have run out of ideas what is wrong.
Help me plz :)
svcdebug.log
It seems you do not select video and audio transcoding settings. In this case you should use direct streaming.
It seems it can not create listen to the output port:
[00a0ae90] main access out: creating httpd
21.04.11 19:58:20.647 VLC [00a0ae90] main access out error: socket bind error (No error)
21.04.11 19:58:20.647 VLC [00a0ae90] main access out error: cannot create socket(s) for HTTP host
Maybe your AV program or another program does interfere?
Hey Lars,
Actually its a fresh install of windows, no antivirus and no firewall.
The only thing I installed are the zotac motherboard drivers, RS, DVBViewer and VLC.
Nothing else, but atleast this gives me a hint to what is wrong, so I have to work on it.
Thx
Best Regards
Lars Bartel
